Mike Mike Motorbike
State Of Confusion
RicJones wrote: Instead of a jeep, have you considered a side-by-side?
Must be street legal and need at least 4 seats
Everybody going faster than me is a "Maniac".
Everybody going slower than me is a "Idiot".
Don't they know I'M going the right speed.....LOL
mapguy
Puget Sound
Trailer weight numbers look odd...for pin and axles. Looks like the trailer was weighted with landing gear down and supporting front. This would not be an accurate weighting procedure.
Empty pin should be 2000 - 2500 depending on propane, batteries, and if a generator is installed.
Empty combined axle weight should be more like 8K or more depending on sidewall type and options installed.
Most accurate weights are calculated from back to back scale passes. First pass hitched up
Loaded Truck Front Axle
Loaded Truck Rear Axle
Trailer Front Axle
Trailer Rear Axle
Unhitch and run truck thru again.
Truck Front Axle
Truck Rear Axle
Front Axle payload
Loaded Truck Front Axle - Truck Front Axle = FA payload
Rear Axle Payload
Loaded Truck Rear Axle - Truck Rear Axle = RA Payload or PIN
Trailer Axle Weight
Trailer Front Axle + Trailer Rear Axle = combined axle weight
Mike Mike Motorbike
State Of Confusion
Ya seemed weird to me too.
I did the green light one axle at a time thing butt.....
Tell you what I'm gonna go through the trailer and re evaluate the stuff inside.....
Mike Mike Motorbike
State Of Confusion
Jeep 151"long x 66" wide x 72"High
tracker 142"long x 64.2" wide x 65"High
Samurai 135"long x 60.6" wide x 64.6"High
05 Rage'n falcon 5er can fit about 148"long x 76" wide x 70"High
........................OR.........................12' 4" long x 6'4" wide x 5'10" High
edited 08/31/09 04:55pm by Mike Mike Motorbike *
LanceUppercut
So Cal
I haul a Samurai in mine and I would recommend it to anyone. They are cheap, fun and light. I have had four 220 pound plus guys in it and it wheeled like a champ, although I do have really low gearing. I can also open the driver door while it is parked in the center of the toyhauler.
2006 Next Level 28CK
2006 GMC Sierra CC/SB 4x4 D/A LBZ
2005 CRF450R
Mike Mike Motorbike
State Of Confusion
I measured a 95 jeep wrangler.
The right rear bumper-et is seven inches long if I take that off or replace it with a shorter bumper it will fit in the Rage'n , if I back it into the trailer.
Right now its only an inch too long.......
Mike Mike Motorbike
State Of Confusion
I sold My ( Non Towing...) truck
And an a dirtbike I never rode.
I have some money and I can't stop thinking about buying a Jeep.
SO I"M GETTING ONE AND I WILL MAKE IT FIT .....
Whoof I feel better....
TRIPLE8
Crestline
Hi, since you have a 5er, you could just add a hitch and flat tow a jeep or samurai.
06 chevy silverado 2500 d-max
06 stellar fith wheel
02 yzf 426
05 yzf 450
04 yz 125 (sons)
06 hon 90 (daughter)
06 hon 300 (wife)
87 zuzuki samurai locked and loaded
glamisorbust
Arizona
I have a 1988 samurai that I haul inside of mine. I have about 14'6" from the rear door to the first cabinet. If I put my wife's TRX450ER quad in the kitchen, I can put the samurai right behind that, and still have room enough for two atc's (three wheelers) sitting front to front in the rear. The samurais are fun and I feel like not that many people even consider them. I would recommend this to anyone, as the sammy is light. I have a door sticker in mine saying it weighs 1900lbs. I can haul four full size adults and fit into LOTS of places a jeep cannot. They are great on gas(about 25mpg)driving it like you stole it. Plus, mine has air conditioning and a nice stereo with amp and sub. I can take the top off or leave it on, and I can drive it on the freeway. Plus, I get to shift my own gears(no belt to slip or snap). I paid only about $1000 for mine, plus a tune up etc. which brings me to less than 2k and i've has so much fun in this thing it's hard to describe.
KF6PLH
Sierra Madre, CA
I haul my 4300lb jeep in my triple axle TH. When I first started I tried to make my F250 do it and I was disappointed. The brakes were inadequate and the transmission constantly over heated. I'm glad I sold the truck before any thing bad happened to it.
I have seen a lot of people haul Zukes in their TH's.
2008 Ford F450 Lariat 4X4 LOADED
2007 Weekend Warrior CR3705
2003 Jeep Rubicon O||||O
UPS Feeder Driver
Ham call sign KF6PLH
