RV.Net Open Roads Forum: Fifth-Wheels: Pull weight??
 > Pull weight??
Fifth-Wheels Related Tips
dellco*
Saskatchewan
Posted: 07/29/09 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about purchasing a 2003 28' Topaz the weight on it says 9960 lbs. Would I be able to pull this with my 2003 F150. Not sure what other info you would need, so let me know. Thanks.
F100jetmech
Chiloquin, OR
Posted: 07/29/09 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I would not. The 9960 lbs is more than likely "dry" weight, loaded ready to camp you will probably be pushing 11500-12000 pounds. That would be VERY heavy for a half ton truck.
On edit- I looked up the tow rating for 2003 F150's. The highest tow rating for any configuration is 8800 lbs.
* This post was edited 07/29/09 08:23pm by F100jetmech *
Pat
'98 Chevy K2500HD 4x4 454 3.73
'06 S&S Montana Bitterroot 8.5 ASC
'00 FR Sandpiper 30SPCS 5er Toy Hauler
kknowlton
Wisconsin Border Country, IL
Posted: 07/29/09 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Loaded pin weight will also be important for you to know, as well as the payload rating and GAWR (gross axle weight ratings) for your truck.
I agree, probably way too much for that light a truck.
amxpress
Clayton, NC
Good Sam RV Club
Posted: 07/29/09 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Is the 9960# the empty weight or the GVWR?
Any idea what the fiver's pin weight is?
What's the payload of your F-150? Maximum tow rating?
Need information!
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
Travel in peace, left the M-I-L at the zoo with her relatives...
donawilcox
Taylor TX
Posted: 07/30/09 01:27am Link  |  Quote  |  Print  |  Notify Moderator
That is the weight of mine dry and have a 3/4 ton duramax and would not even think about using a 1/2 ton. unless you live in flat west texas and your trips are short and you beef up your trucks suspension may consider for a short time. I will probably go 1 ton on my next truck.
There are some lighter fivers that your truck will handle.
Don Wilcox
Taylor TX
2006 Duramax 4X4
2007 295 Cherokey by Forest River
TXiceman
(Near) Houston,TX
Posted: 07/30/09 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I would not even try it. You are asking a boy to do a mans job.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Vulcaneer
Northern New England
Posted: 07/30/09 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I am afraid your truck is way too undersized for the task you describe. I wouldn't try it either. Installing a fifthwheel hitch in that truck would be a waste of money, if you expect to pull that trailer.
If you must use that truck, go for a smaller/lighter 5'r, or a TT with much less pin weight. JMHO
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
dellco*
Saskatchewan
Posted: 07/30/09 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ok! So that's settled then. LOL. New truck if I want this camper. Thank for the replys.
jetboat
texas
Posted: 07/30/09 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
i would not,stay with in your weight range,or move up to a larger truck,and trailer.they go hand in hand.
smkettner
Good Sam RV Club
Posted: 07/30/09 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
F150 with the HD payload package could carry and pull that one.
OEM seven lug steel wheels will indicate the proper equipment.
 > Pull weight??
