RV.Net Open Roads Forum: Tech Issues: Dometic Recall
 > Dometic Recall
787dreamer
WA
Posted: 08/07/09 10:14am Link  |  Print  |  Notify Moderator
Has anyone been succesful in getting Dometic to fix the actual root cause? Most people think that the SBH Kit fixes their problem but it is ONLY a band-aid fix. Dometic should be required by law to replace the entire cooling unit due to the Fatigue crack in the Boiler tube. All the SBH kit does is keep any fire from spreading. IT DOES NOT fix the bolier tube. SO here I am the recall was done on my unit and 1 month after the recall repair guess what... I got a fatigue crack in my boiler tube which leaked out all of the cooling fluid. Talked with Dometic and they said tough luck the recall fix was done. I say BS the root cause was not fixed.
tvman44
Southwest Louisiana
Posted: 08/07/09 11:31am Link  |  Print  |  Notify Moderator
I agree with you but looks like that is all they intend to do about it. And the consumer gets f????? again.
Papa Bob
Husky 16K hitch, Tekonsha P3,
firecapt1
Sonoma County, CA
Posted: 08/07/09 12:08pm Link  |  Print  |  Notify Moderator
The only way to get them to deal with the problem would be if someone filed a class action lawsuit. I imagine there are enough folks out there that have had the same experience as you.
Frank, Martha & Ryan
2007 Ford F-250 SD Crew Cab
2006 Cougar 289EFS
Happy Trails to you, until we meet again! ">
jetcare
Mobile RV Repairman - Mission, TX
Posted: 08/07/09 08:44pm Link  |  Print  |  Notify Moderator
787dreamer,
How old was your refrigerator?
Matt
2016 F-250 Crewcab 6.2L 4x4
2012 Palomino Sabre 32' Travel Trailer
787dreamer
WA
Posted: 08/08/09 09:35am Link  |  Print  |  Notify Moderator
It was a 2000 RM3663 Royale model.
heavyequiptmentmover
Huntington Station ,New York
Posted: 08/08/09 06:30pm Link  |  Print  |  Notify Moderator
I dont believe ther are many OEM's that will replace beyaond the warranty period.
Bipeflier
Centralia, MO
Posted: 08/08/09 07:04pm Link  |  Print  |  Notify Moderator
They actually replaced my cooling unit a year ago. The "kit" had been installed earlier then the boiler cracked.
It was almost 3 months out of warranty but they stood behind it anyway.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
 > Dometic Recall
