RV.Net Open Roads Forum: Towing: ford explorer 2006
Search only in Towing
Open Roads Forum  >  Towing
 > ford explorer 2006
Towing Related Tips
ferly27
laval
Posted: 08/10/09 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hi I just purchased a explorer 2006 v8 and took out my 26ft 4000lbs trailer for the first time. the truck pulled it more than easily but experienced alot of sway!!!!! I have the torsion bars and sway control installed. Used to tow with a 2004 dakota v8 4.7 it ha da harder time towing but never swayed.
the ball seemed a bit higher on the explorer so i lowered it hoping that was the problem... since the back of the rv was lower than rhe front
Any help would be appeciated.
thx
Turbo Diesel Dude
Green Mountain, NC
Good Sam RV Club
Posted: 08/10/09 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Probably P rated tires and soft suspension. JMHO
charles weidman
Road Ruler
Canada
Posted: 08/10/09 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Can you post some pics of your set up? That Explorer with the IRS should be better overall than the Dakota.
Airstreams.... the best towing trailers on the planet!
YC 1
Yuba City Calif.
Posted: 08/10/09 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely check tire ratings and pressure. Also check your loading so you have the proper tongue weight. Your shocks probably need to be replaced though I doubt they have much effect on sway. Try to tow the trailor dry if possible.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
bobofthenorth
Somewhere in North America
Posted: 08/10/09 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
An Explorer towing anything is an accident looking for a place to happen. The shortest Dakota wheelbase is as long as your Explorer. Your Dakota may very well have had a 20" longer wheelbase than your Exploder. I have an Explorer Sport-Trac and I consider it a marginal tow vehicle for a light boat. You are simply asking too much of it. IMNTBHO
My website
My weblog
skipnchar
Topeka Kansas USA
Posted: 08/10/09 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
What TYPE of anti sway system are you using? Is it set up CORRECTLY? Assuming you have a friction bar. If so is it tightened COMPLETELY or are you trying to ADJUST it by using the handle (can't do that). Tires and suspension COULD be part of your problem and a high tongue can cause sway issues also so there are a lot of possibilities without much information from you to help in correcting it.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
kknowlton
Wisconsin Border Country, IL
Posted: 08/10/09 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of possibilities. IMO, 26' is too long for an Explorer, but with a really good sway control system that's set up properly, you should be at least marginally ok. (Assuming all the weights are within specs.)
Claude B
Montreal, Canada
Posted: 08/10/09 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Ferley 27,
Who set up your WDH ? TT and TV level, bars parallel with the TT tongue ?
You live in Laval, is this Laval QC ?
Claude & Lise
Nissan Pathfinder 4WD 2003, V-6 3.5L, auto tran, 4.36 diff., Palomino 2003 ultra lite TT (T-25FB) 25' (loaded: TT 4,200#, all together: 9300#) Reese WD hitch 750# bars, Dual-Cam, Prodigy
bobofthenorth
Posted: 08/10/09 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Swaybars are no more use than a bandaid on an amputation.
Too little truck and too much trailer.
BCTrucker
Chilliwack, BC
Posted: 08/10/09 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
We towed a little 18 foot Keystone Hobbi Toyhauler, and it was way too much for the '03 Explorer Limited V-8 we were using, to the point that it bent one of the rear axles, even with properly attached sway control, we had that thing way overworking.
