gafidler
Kempner, TX
Good Sam RV Club
Don't know if anyone else has this problem,,I have a 2010 Windjammer by Rockwood with 30 AMP service, A/C. has 20 Amp breaker and Microwave has 15 AMP breaker. When I try to run both at the same time of course it trips the main breaker. You would think that someone in designing the trailer would have thought 15+20= 35. this will not work..
If anyone has a idea how to fix the problem I would appreciate any help I could get... Turning the A/c off to cook is not the answer.
Thanks for your help..
SUKISHORT
SO CAL
Good Sam RV Club
Are you running anything else, like coffee pots, toaster, ect. The only time they main should pop is when both the compressor and the microwave cycle at the same time. If nothing else works, just raise the temp on the A/c for a few mins while you microwave. Good Luck
skipnchar
Topeka Kansas USA
In my Rockwood I have no problems running both at the same time at least for a short time. We don't use the microwave for roasting turkey or anything that takes a while.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
You can't take the Fisherman out of this Camper
Ontario, Canada
Good Sam RV Club
gafidler wrote: Don't know if anyone else has this problem,,I have a 2010 Windjammer by Rockwood with 30 AMP service, A/C. has 20 Amp breaker and Microwave has 15 AMP breaker. When I try to run both at the same time of course it trips the main breaker. You would think that someone in designing the trailer would have thought 15+20= 35. this will not work..
Thanks for your help.. You have answered your own question: Turning the A/C off IS the answer! The only other alternative is to upgrade your electrical panel as well as the cable and go to sites with a 50 amp service!
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS & 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
mhawk4
South Carolina
Good Sam RV Club
SUKISHORT wrote: Are you running anything else, like coffee pots, toaster, ect. The only time they main should pop is when both the compressor and the microwave cycle at the same time. If nothing else works, just raise the temp on the A/c for a few mins while you microwave. Good Luck
i agree, the only time i had this problem before i was running my water heater on electric in combination with the ref, a/c and micro. now i run my water heater on prop., no more issues for me.
2002 Ford Excursion XLT 6.8L,V10 3.73(TB2)
1999 Chevy Suburban 5.7L,V8 3.73 (BUDDY)
2008 Jayco G2, 27BH (MHAWK)
HP dual cam
Luis,Shelia,Noah,Gabriel
All about the family!!
sure2rain
Sunbury, PA
Good Sam RV Club
Agree with mhawk4 about the possibility of the AC, Microwave and water heater being the reason for the circuit overload. I can run the AC and Microwave together without any problem as long as I flip the circuit breaker for the water heater to off.
TV: 05 Chevy 2500 8.1L
TT: 2005 Citation--LYTR
Hensley Arrow and P3
ritablack
Hazleton, PA
Good Sam RV Club
If there is a lot of demand from other RV's in the area, you might not be gettin full amps (?) A fellow RV'er showed me an AC voltage meter that plugs into a socket. She checkes it before turning on any second item that draws a lot of electricity. It can be bought at Camping World. She says that this helps to kept her breaker from tripping.
Rita Black
Grey Bear-2005 Chevy Trailblazer
Eaglesnest-2006 Wildwood 21FB
robbie69
wauconda, il usa
have the same sort of problems-popping the breaker and it's usually the ele water heater that puts the draw over the edge, and one of the things easiest to forget about. know i did, took me a long time to get it figured out-just was one of those thing that didn't register till i sat down and gave it some thought as to why the breaker popped. now i'll just turn the ele switch off and the gas one on.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
roamerr
NC
Summer = Water Heater on Propane Only.
If I try the water heater on electric in the summer my kids will fire up the hair dryer after taking a shower while trying to watch TV waiting on the popcorn snack to finish popping. All of that and they will bump the AC down since it's hot.... Heck -- they could make a 50 amp breaker trip.
2009 Cherokee Wolfpack DFWP27 Toyhauler
2008 Dodge Ram 1500 Hemi Quad Cab w/3.92
Can-Am Outlander 800 XT
Yamaha Rhino 660
Honda Recon
Honda XR200R
2 dogs - Basset Hound and German Beagle (mutt)
Great Family Fun!!
Chuck&Gail
In the Colorado Mountains
IMO depends on A/C size, and microwave power. Our microwave is a bit over 1k watts, and A/C is 15k btu. Can't run both on our 30 amp rig even with electric water heater off.
Simple solution is to buy a 50 amp rig, or turn A/C to fan only while using microwave. We choose the later.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
