RV.Net Open Roads Forum: Class C Motorhomes: What does a slide weigh?
 > What does a slide weigh?
Class C Motorhomes Related Tips
greydawg
Livingston TX
Posted: 08/11/09 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I had a conversation with a friend about my ongoing 22-24' used RV search, and the list of "musts" and "wants."
Me: "Nope. No slide."
Friend: "Why? there are lots more recent units with slides on the web."
Me: "I don't really need the extra room, and I don't see any reason to add that weight to the RV."
Friend: "What does a slide weigh? How much are you adding over just a plain wall with windows? Enough to worry about?"
Me: "I dunno, exactly, but they've got to be pretty heavy, right?"
OK. So what's the (ballpark) answer?
(Consider a slide in a 2004-2008 Class C,big enough to accomodate a dinette or a jacknife sofa, not a super slide.)
Thanks!
erstanfo
Northwest, Olympia WA
Posted: 08/11/09 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
My 2006, 2600SO Ccoachmen that is 28' long only weighs 8,500 lbs (weighed at local HWY department truck scale) full of gas, full fresh water, typically loaded (food, bedding, clothing, chairs ...) including the slide. So if you want the room, get a unit with slide. When we were looking at used units back in Febuary, we preferred all the units with slides. for future resale, lots of folks will be looking for slids. We like the extra room.
Ed, Sharon & Doolin the standard poodle
2006 Coachmen Freelander 2600SO, previous rental, E450, Blistein comfort shocks
ron.dittmer
I Will Be Dancing With The Stars On 1/23
Posted: 08/11/09 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am with you greydawg on this one. I was told the slide option (a little slide I did NOT order) for My Motor Home would have added 400 pounds to my model RV.
See the slide option Here but don't be confused with the bigger slides available. It is the couch alone in the slide.
My wife & I are "Dancing With The Stars" for PADS on 1/23
Read about it in my "View Profile"
Then scroll down to "More About Me"
MrTravelDecal
wandering
Posted: 08/11/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2000 24' Minnie that weighed 10,720 at a CAT scale located @Flying J. This was without water but had full propane and gasoline tanks. Also me and the small dog too
E350 , V10 , No Slide
3580 steering axle
7140 drive axle
* This post was edited 08/11/09 05:32pm by MrTravelDecal *
If the plan is so great, why doesn't it sell itself?
skipnchar
Topeka Kansas USA
Posted: 08/11/09 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
About the same as a box. Slides come in all sizes and shapes and weight will depend on a LOT of those type of things.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
kaagee
Burlington Ontario
Posted: 08/11/09 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
My guess would be...800lbs..
Ken
Jim&Peg
Central Ohio
Posted: 08/11/09 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of the extra weight of a unit with a slide is in the deeper frame required. A lot of trailers that were built without a slide had a 6" frame. With a slide they need a 10 to 12" frame because the slide rails must pierce the frame. You can't put a 3" hole through a 6" frame and have adequate strength.
greydawg
Livingston TX
Posted: 08/11/09 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies and ballpark guesses!
Having to beef up the framing around the hole in the wall makes lots of sense. Then add the slide box with floor, sides and roofs, and a mechanism...
So my ballpark guesstimate for a 22-24' Class C with a relatively small slide will be about 600 lbs (mean of the 400 and 800 lb guesses above) increased weight -- more or less!
YMMV.
Thanks!
AstroRig57
near Tehachapi, CA
Posted: 08/11/09 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, that doesn't seem right!! I don't know what to tell you other than that maybe you'd better check that weight again. I'm looking at a Coachmen brochure, right now, that says the curb weight (CW), EMPTY, of a 20006 2600SO is 10,523 lbs. Heck, even the 2400WB has a curb weight of 9958 lbs. I don't see any reason why it would benefit Coachmen to overstate the curb weight of a unit. Are you sure you didn't weigh just one axle?
The Coachmen website defines curb weight (CW) as:
CW (Curb Weight): The weight of the unit without factory or dealer installed options, plus allowance for the weight of full fuel capacity. The "payload capacity" for all other fluids, cargo, occupants, optional equipment and accessories can be determined by subtracting the CW from the GVWR.
2005 31' Coachmen Freelander 3150SS, Stargazer II - Mobile Astronomy Unit
Do you remember when the sky was dark, and the stars were bright?
The International Dark-Sky Association
American by birth...Scottish by the Grace Of God.
klhutch
Sububan Chicago
Good Sam RV Club
Posted: 08/11/09 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, my 23 foot 2130QB weighs more than that loaded for a trip. Something's not right, maybe just a typo.
On the subject of slide weights, as someone said already they are all different, you will have to ask the manufacturer if you want to know what a specific model weighs. I've seen slides add as little as 200 pounds on Sprinter class C's that give enough weight data to make the calculation. They are worth it spacewise although floor plans that were designed without slides are often very efficient in their use of square feet. On some slideout models the interior is pretty cramped when the slides are retracted. That is generally acceptable but it could be an issue for some MH's or owners.
Ken
