David1976
Philly PA
Good Sam RV Club
I've been looking around and I've notices that many posts are cut off in the middle and I can't scroll down. I use firefox if that makes any difference.
Thanks
David
2004 Dodge Ram 1500 4x2
2004 Aerolite 26Q
skipnchar
Topeka Kansas USA
Maximize your browser window and it may help
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
2oldman
Indio CA
What kind of internet connection? A really slow one will do that.
David1976
Philly PA
Good Sam RV Club
The browser's full size and everything looks like it loads. I've got 25mb internet.
It looks like there should be a scroll bar, but there's not.
2004 Aerolite 26Q
David1976
Philly PA
Good Sam RV Club
Here's the Dexter HD Suspension & EZ-Flex Install thread in the TT section. See what I mean?
2004 Aerolite 26Q
2oldman
Indio CA
A link to that post would be most helpful. Too hard to find.
David1976
Philly PA
Good Sam RV Club
I think I just found something... It looks like it's the good sam club interface. If you click here
http://www.goodsamclub.com/forums/default.aspx
Then go to Travel Trailers, then it's the second pinned link.
I did a right click and copied the link location and when I open this link, I can see the full post.
http://forums.goodsamclub.com/Index.cfm/fuseaction/thread/tid/21609645.cfm
I guess they use frames or something like that and the post with the pictures is too long to be displayed and gets cut off...
2004 Aerolite 26Q
2oldman
Indio CA
It must be your browser.
David1976
Philly PA
Good Sam RV Club
I tried it on
Vista with IE7 and Firefox
XP with IE8 and Firefox
and Windows 2000 with IE6
All have the same problem. If I go directly to the forum url it's fine. If I start at www.goodsamclub.com and click on community then forums I can't see the full post; it's hidden... But it's only on longer posts. Stuff with a couple posts and no pictures is fine, but longer threads with lots of pictures get hidden. If I use forums.goodsamclub.com and bypass the interface everything is fine.
2004 Aerolite 26Q
tvme
Medina, Ohio
David,
I have the same problem on the Good Sams portal using IEX. I figured it had something to do with my security settings (no stored/ nasty cookies, no Active-X, no java, and I try to avoid as much google-garbage as possible).
Try the Trailer Life portal. You should be able to read the threads. However I'm unable to log in to reply on the TL portal so I just use Good Sams as a "window" for replies. All in all, a real pain in the...
Bob
