RV.Net Open Roads Forum: Travel Trailers: Second Tire failes
 > Second Tire failes
Travel Trailers Related Tips
indymom2009
Lawrenceburg, IN
Posted: 08/13/09 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
My neighbor had two of his Carlyle tires blow on his TT last week on their way to Myrtle Beach, they were both less than 2 years old.
Jerry9n
SE Michigan
Posted: 08/13/09 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
I am beginning to think after reading many threads (these seem to sprout once or twice a week in various formats) that there are as many opinions about tires as there are tires. You can search for a specific tire by name and spend the night following posts.
I got a set of Duros on my trailer in August (they were built in June) and after four trips and 1400 miles the sidewalls and treads cracked. I guess this is common for some Duros (others have posted no problems with these). I turned them in for warranty but could not bring myself to put them on. I ordered some Denman Express tires. All I can say at this point is they look good and were made in Mexico.
Others seem to have had good luck with Denmans, Maaxis, and US Goodyears. That does not rule out that some have had good luck with other brands. Also remember, the number of people posting here is rather small when compared to the number of trailers (and tires) that are out there.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Voyager
HTT Mods
Husker Jerry
O'Neill, Nebraska
Posted: 08/13/09 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote here for Maxxis. A year ago I went to load range E tires on my TT. So far so good.
I'm aware of the 65 MPH restriction on ST tires but have never heard an explanation as to why. Could someone enlighten me in this regard???
2001 Ford Excursion V 10
2003 Jayco Designer 31FKS
Twin Honda Eu2000 gen sets
H & E
North Texas
Posted: 08/14/09 04:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all
I will start looking today. Our TT weighs in at 6960 pounds fully loaded for our travel. I drive at 60 to 65 most of the time if the road and limits permit. On rough roads I slow down. I tried driving at 55 for a while to help the fuel burn but there was not any appreciable difference. I am convinced that my problems are junk tires. We are in PA this week and one of the seasonal guys here is a tire dealer and is coming by this morning.
H & E
Turbo Diesel Dude
Green Mountain, NC
Good Sam RV Club
Posted: 08/14/09 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Maxxis ST225 75R 15E will serve you nicely. STs are rated for 65mph. My Ds were inflated to 65psi and I inflate my Es to 80psi. No problems and I've towed with temps up to 102* ambiant at 62 mph my normal speed. JMHO
charles weidman
Midnightpumpkin
Concord Twp, Lake County, Ohio
Good Sam RV Club
Posted: 08/14/09 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Howard,
A couple of things to be aware of specific to your Rockwood.
1. The wheel rims are 5 inch, this limits you to a ST205/75R15 tire, unless you invest in new wheels.
2. Denman makes a ST205/75R15 load range D tire. Neither Maxxis or Goodyear offer this tire. The others that offer it are Chinese.
3. If your posted weight is the weight on the axles, you need to try to shed some weight, if it is total including hitch weight you are ok. The trailer axles are only rated at 3500# each.
Good luck and I hope the rest of you trip is uneventful!
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
NickG
Warren, Michigan
Posted: 08/14/09 07:42am Link  |  Quote  |  Print  |  Notify Moderator
On a tandem axle trailer, carry two spares.
When a tire blows, you immediately overstress the tire that is still aired up on the same side as the blown tire. Many change the blown tire only to have the other one blow out shortly after. When this happens, you then overstress the new tire.
When you have a blowout on a tandem axle trailer, replace both tires if you can.
2004 2500 GMC Savanna 6.0 / 3.73
2001 Mallard 30E
Wife,
Triplets born 10-14-02 (2 girls, one boy)
Older daughter born in 1985
Choc lab named Kia (No, NOT after the car!)
http://mywebpages.comcast.net/babies3/index.htm
cpachristopher
Central Oregon
Good Sam RV Club
Posted: 08/14/09 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I am relatively new to this business of hauling a big old thing behind me, but have been concerned about tires since I started. I check my air each stop, drive at a reasonable speed, etc, but in the back of my mind are the videos made by Michelin!
Anyhow, I was curious about speed ratings of the ST tires and came across this article. I suppose it is not new to most of you, but I found it very good reading. For instance, I did NOT know about the sidewall strength of ST tires.
http://www.discounttire.com/dtcs/infoSeparationAnxiety.dos
Good reading!
2008 Fleetwood Redline
2005 F250
jfs999
Stafford Va
Posted: 08/14/09 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I got a set of 15" D rated Maxis from this place online. They also had E rated tires and offered free shipping.
kaydeejay
SE Michigan, USA
Posted: 08/14/09 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Good reading!
clicky Definitely good reading
