bf3366
Grants Pass, OR
HR owners...we have the "water management" system on our RV. There is no gravity flow filler. The manual states that if you put water in the tank from a non-pressurized container (bucket), that you need to use an independent pump. I have put small amounts of water from a bucket, using the 5ERS water pump. Although it is quite slow, and you must elevate the water container, it does work.
I am planning a dry camping trip soon, and will need to put water in at the camp site. Was hoping for some feedback from you folks who have the same setup...not necessarily an HR rig.
I did ask my dealer about the independent pump thing. He said it was not necessary.
2001 Ram 2500, 4x4, Quad Cab, Diesel.
RBW Li'l Rocker 15K Hitch.
2004 Holiday Rambler Alumascape 30SKS.
whiteeye42
Rock Springs Wyoming
my jayco has the same set up as yours i have used the pump on the 5'er to fill the tank for a bucket and you are right it is slow but this year i bought a pump and mounted onto a piece of plywood and hook it up to the batteries and use it to pump from the bucket or a water jug using the city water fill on the water management system and it only took about 5 minutes to empty a 6 gallon jug and that was while we were boondocking 27 miles in the back country worked great.
Me,Wife two boys ages 21 and 19 also two dogs
2008 Dodge Ram Quad Cab 4x4 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with b&w turnover ball & companion hitch
using rotochoks
add state map
byronlj
Loveland, CO/Lake Havasu City, AZ
I have the same setup on my rig and it works just fine. Maybe you have a small leak in one of your connections or your hose is collapsing under suction. Mine will pump from a barrel @ about 3/4 the pace of a pressurized hose.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
BIKERK9
Santa Cruz, CA
Good Sam RV Club
Who wants to strain their back and arms to lift and hold water jugs up high to a filler spout.
When I can not connect to a water faucet to fill my tanks, I devised something to make life a little easier.
I have an auxiliary 12v water pump that will draw water out of a primary bucket and push the water
thru filters and into my water tank. The water can be from any potable water source to include
captured rain water. I just need to fill the primary bucket as needed with potable water and exercise
water conservation when dry camping.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
paztruck
San Diego, CA
Good Sam RV Club
I got a pump and a couple 6 gallon water jugs that I adapted the top to accept the hose fitting. It works very well for me, I got tired of lifting and spilling the water.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
LEN Retired
SW Michigan ( Two Paws )
Good Sam RV Club
My 07 HR has the same set up and I use the units water pump with a 3 foot hose which I place in a water container it may be a tad slower this way but works for me. Bill
06 GMC 2500HD Duramax, 2007 Holiday Rambler Alumascape Suite 32SKT,3 slide 5th wheel " SEMPER FIDELIS "
bf3366
Grants Pass, OR
Nice dog.
LEN Retired
Good Sam RV Club
bf3366 wrote: Nice dog. thanks, she's always a happy RV'er (camper)
