13ronzo
Englewood FL
Hi,
Just a quick question on pac brakes. Do you drive with it on all the time or switch it on when you feel the circumstances warant it?
Thanks,
Ron
wolfe10
I do NOT drive with it on all the time-- I would really miss my favorite "gear"-- COASTING.
I do drive with it on all the time in stop and go traffic ONLY.
Other than that, I only turn it on as needed AND use transmission down/up arrows to select the gear I want (I had Allison ECU reprogrammed for a 5th gear pre-select).
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
TMitchell
Punta Gorda, Fl.
Good Sam RV Club
I keep my exhaust brake on full time. The best way to maintain one is to use it.
On my setup, it is very easy to feather the fuel pedal when I want the pac brake to disengage while coasting.
The problem I have is I should use the service brakes more then I do, to keep them in good shape. Each trip,I have to remember to do a few reasonably hard stops to keep them cleaned up.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
Robert H
Crestline,CA,US
I do NOT use it all the time. . .only when in traffic
RayChez
Barstow, Ca. USA
I don't leave it on all the time, unless I am in heavy traffic or driving on the mountains.
Fishinghat
Western Washington, USA
I last turned it off over five years ago and didn't like the free wheeling "coasting". It's been on all of the time since, including several trips over the Siskiyou mountains in winter.
The instruction manual says to leave it off in ice and snow, but that's when I really like the retard feature of the exhaust brake. I can slow the coach down without locking up the front brakes and loosing steering. It's like gearing down in a sports car in slippy weather to maintain control.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
Executive
Northern California
Mine stays on all the time and I use it regularly.....109,000 miles on the clock and 70% left on the service brakes....I'm good with that....Dennis
Dennis and Debi
Monaco Dynasty Baron 40PFD
Towing a Chevy HHR W/
ReadyBrute
JohnJr
Temecula, Ca
Good Sam RV Club
I don't have an on/off switch. I have a foot switch. The pac brake is on when I step on the switch and off when I don't. I use it all the time.
JOHN and DALE
JAVA and LUCY (Mini Australian Shepherds)
1996 MONACO DYNASTY 34"
BULL DOG
CLARENDON HILLS, IL.60514
I had to have 2-injectors replaced while driving thru Colorado into Nevada, then by the time I went thru CA & back home to Illinois another two injectors had to be replaced.
The Cummins mechanic said using the Pac Brake is hard on them & recommenced not using it for long periods of time so the cylinders could get a chance to cool down.
400 Cummins
JOSEPH R TOVO SR
Sully2
Cincinnati
Good Sam RV Club
BULL DOG wrote: I had to have 2-injectors replaced while driving thru Colorado into Nevada, then by the time I went thru CA & back home to Illinois another two injectors had to be replaced.
400 Cummins
I dont believe THAT for a second!
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
