RV.Net Open Roads Forum: Technology Corner: Aaaargh! Tuning my Directv dish!
 > Aaaargh! Tuning my Directv dish!
Technology Corner Related Tips
Lightload
Spring Mills, PA
Posted: 08/25/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I just had my Directv receivers and satellite dish upgraded. I took the new receiver out of the bedroom and took it out to the camper to see how it would work. I hooked up the receiver and then navigated to the "signal strength" meter. Hmmmm, no beeping....
From where I had the dish located, I could look through the camper window and see the tv screen so I was able to watch the strength bar and get the dish aimed correctly.
I figured there had to be some way to turn on the "beeping" but I looked in all the menus and could find nothing. After the technician installed my new equipment he left me his phone number in case I had any questions so I called him to ask about the beeping signal strength meter. He told me THEY DON'T BEEP ANYMORE!
If the DW is around, she can watch the screen but what do you do if you're by yourself and you have to position the dish somewhere where you can't see the tv?
Anyone come up with a solution to this problem?
2002 F-250 full size ext. cab Powerstroke
2005 31' Prowler Bunk House TT (for the grandkids)
Always try to be the person your dog thinks you are!
ernestfortier
Palmdale, Calif.
Good Sam RV Club
Posted: 08/25/09 08:22am Link  |  Quote  |  Print  |  Notify Moderator
When I had my TT and had to set up a portable DirecTV dish I had a small TV set that I could take out with me and hook up a short cable to. It was a lot easier to find the signal by watching the TV than to be yelling back and forth for signal strength.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
kelvin sky
Sterling Ma / Naples Fl.
Posted: 08/25/09 08:25am Link  |  Quote  |  Print  |  Notify Moderator
The signal is hard to find..
This will do the trick
$ 15.00
2oldman
Indio CA
Posted: 08/25/09 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Is this a new HD receiver? What kind of dish?
Lightload
Spring Mills, PA
Posted: 08/25/09 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it's a new HD receiver with an 18" round dish.
YC 1
Yuba City Calif.
Posted: 08/25/09 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I had little luck with the $15 meters. Seems the only thing they did was make a loud noise. I covered the hole with tape to quiet them down. They just don't seem to have a very smooth tuning curve. They work, just not great. I bought a good meter though pricey that I love. I don't need the receiver to set up the dish because it has a built in battery. The Satellite Buddy works well for me.
My HD receiver does not have the beeping either. It has the menu to turn it on and off but it never has beeped. My standard def receiver beeps.
Your round dish needs to be compatible for the high def to work properly. That said, I have a standard dish with two lnb feeds that I used last week to run my HD receiver. What happens is that you tune to a HD channel and it says call Direct with error 771 or such. The solution is to go into the menu system and set up a seperate "favorites" list that has only standard definition channels. It will record and play back just fine then without the error messages. If you don't have the HD dish then you won't need any B band converters that may be attached to the inputs to your receiver.
Now you might have a new dish with SWM (single wire multiplex) and be just fine with one wire going into the HD receiver. I haven't tried one of those yet but will in the next few weeks at my year round rv park.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
chi6488
florida
Posted: 08/25/09 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunatly you will have to wait until wife is there. Mine does not beep either. You could get several mirrors and line them up.
Those meters will tell you other sats as well. I don't even use the meter anymore. More trouble than it was worth.
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
TomG2
Central Illinois
Posted: 08/25/09 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I use the handheld meter and it works fine for me. Sweep once and notice any signal at all, sweep second time to pinpoint satellite. Check signal on TV. About six or seven minutes for a great signal with DISH. Being single, I had to come up with something.
2oldman
Indio CA
Posted: 08/25/09 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Well, this is not good news. I've relied on beeps for years with my old Hughes receiver. Drat.. meter time I guess.
creeper
Richmond Hill, Georgia
Posted: 08/25/09 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
$ 15.00
I use the same one, it works great.
Find a sat, turn down the gain, peek signal again, done.
Travel Blog
