njdirt
Monroe,NJ
Good Sam RV Club
Recently in 2 downpours on a 06 W22 Workhorse Allegro Bay something is getting wet and shorting out the wiper control. They wont shut off or go to the intermitant speeds, only low and high until it seems to dry out then OK again. Have put electical tape on the connection hanging down to the motor but havn't gone through a heavy rain again to see if it helps.
Anyone else experience this? Thanks for any help.
Bob/Marlene and Crystal(Golden Retriever)and sometimes Grandkids....
37' Alllego Bay
dirts for racing/asphalt's for getting there
newxmar
East Otis, MA
Many (includin us) have had the same experience. Drying out the wiper motor connector will cure. Also suggest putting connector "upside" down and up out of the way of the water/rain so water can run out. I also potted the connection with electrical putty. In 4 years the problem had not reappeared.
jeepfreak
Hanover Ma.
Good Sam RV Club
you are not alone on this issue. I brought mine in for the same thing while it was under warranty and they said they fixed it. Well 2 wks ago I got caught in some heavy rain and guess what, when the rain stopped the wipers wouldn't. I went to the dealer after work (mh was at home) and I thought they were covered under the Workhorse warranty , which I still have 18 months left, but they told me the motor is a Tiffin item so covered for only 1 yr. They are talking to Red Bay about this as we speak. But mine also don't park at the bottom like there supposed to. They tell me the issue with not stopping is the plug that connects to the motor gets wet. Well the last time when I pulled over to unplug the plug it was dry, so Iguess I'll have to wait to here from the dealer. Just to let know we are not alone with this problem.
2007 Allegro 34wa Workhorse 8.1, Allison 6-speed. Bow Tie powered 79 CJ-7 TOAD ,when A/C IS needed 2000 Grand Cherokee Toad
rolnhome
Pacific Northwest / Mexico
newxmar wrote: Many (includin us) have had the same experience. Drying out the wiper motor connector will cure. Also suggest putting connector "upside" down and up out of the way of the water/rain so water can run out. I also potted the connection with electrical putty. In 4 years the problem had not reappeared.
Yep this is the answer. Seal the pigtail connection from the motor problem solved.
We're in Arizona
njdirt
Monroe,NJ
Good Sam RV Club
Thanks all glad to know not just me!!!!!!!!!!!
1fanman
Cabot AR
Good Sam RV Club
I had the same problem, sealed the connector and problem went away.
1fanman
Del & Carol, (Satina & Muffin) (Pugs)
05 Fleetwood Bounder 35E
Toad 2006 Saturn ION
Blue Ox Tow rig
Brake Buddy vantage
USAF (Retired)26 yrs
USAF Civil Servant (Retired)22yrs
george 37
tennessee
I had this problem and took my mh to a rv repair shop and I had a control circuit panel replaced, It cost $140.00 to fix. Mechanic told me it could happen again if I didn't seal the connection between the male/female plug.
jeepfreak
Hanover Ma.
Good Sam RV Club
Wondering with what and how you sealed the plug?
wilanddij
CA Desert
Good Sam RV Club
I covered mine with silicone grease and put kitchen plastic wrap around it all.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
1fanman
Cabot AR
Good Sam RV Club
jeepfreak wrote: Wondering with what and how you sealed the plug?
Not sure as Workhorse took care of it under warranty but if you want I will be happy to call them and ask.
1fanman
