RV.Net Open Roads Forum: Tech Issues: 12 volt lights
 > 12 volt lights
Tech Issues Related Tips
SkiingSixPack
Minnesota
Posted: 08/29/09 10:05am Link  |  Quote  |  Print  |  Notify Moderator
If anyone have a guess to what happened, please post.... thanks in advance.
I went out to do some cleaning and picking up this morning and a strange thing happened. I went to turn on the lights and none of them worked. I looked and saw the battery light on indicating that at least some power was there. I then turned on the water pump and it worked, I ran some water and it worked fine. Then I tried the stove hood fan and it worked fine. So I looked at the 12 volt fuses and they all looked good. I replaced the back light fuse even though it looked good. I then tried the lights again and nothing.... no lights worked.
Then my son came in asking what I was doing, I said trying to get the lights to work. He then pushed the pump switch off, and held down the same switch to the 'check' position that shows the battery and water levels. Then I turned on a light and it worked.
There was about 2 minutes between the time I replaced the fuse and tried the lights and then when my son pushed the switch and the lights worked. I don't get what happened, but if anyone has a guess, I would appreciate hearing it.... Thanks,
Kent
My much better half
DS-10,DD-8,DS-7,DS-7
Our Fuzzbutt Golden Retriever-12
The greatest thing you ever can do now,
Is trade a smile with someone who's blue now,
It's very easy just...
GTN_and_Catz
Houston
Posted: 08/29/09 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Gene
2003 36' Rexhall RexAir
2009 Jeep Wrangler Sahara
Blue Ox Aventa II
2 Ragdolls
1 Tabby
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 08/29/09 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I would start by looking for a loose connection in the DC power distribution panel. Pay special attention to the grounds. The additional load of pump could have burnt through some corrosion. Many times, rigs have a wire nut connecting the grounds together in back of the power center check for this and make sure it is tight. You could take it apart and clean the conductors. If you do so, apply some electrical grease to the bare wires.
Bud
Suzuki XL7 pushing Pace Arrow
SkiingSixPack
Minnesota
Posted: 08/29/09 11:00am Link  |  Quote  |  Print  |  Notify Moderator
GTN_and_Catz wrote:
SkiingSixPack
Minnesota
Posted: 08/29/09 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I'll do that....
 > 12 volt lights
