RV.Net Open Roads Forum: Hybrid Travel Trailers: Bunk End Latch ?
Open Roads Forum  >  Hybrid Travel Trailers
 > Bunk End Latch ?
Hybrid Travel Trailers Related Tips
popere
Denver
Posted: 08/29/09 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I have been trying to find where to buy the peice of heavy duty foam that goes in between the handle and the latch to prevent the metal on metal rubbing. It has sticky on one side to keep it stuck to the handle. Any idea where I can purchase some of this? I have tried HD and Lowes and neither one have anything that heavy duty/dense.
Thanks in Advance
bamaram2002
Central Alabama
Posted: 08/29/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I couldn't find it either. I ended up using those felt adhesive pads from Lowes for now, but they clearly aren't going to hold up like the foam rubber would.
Mike, Michele, Hannah (13) and Elijah (10)
2002 Dodge Ram 1500 QuadCab
2003 KZ Coyote 23CT
Family Travel Photo Album
Rookiecamper
Northeastern, PA
Posted: 08/29/09 10:39am Link  |  Quote  |  Print  |  Notify Moderator
I had ski boots custom fit to me at a ski shop and they used super dense, 1/8" stick on foam to help adjust them. Perhaps living in Denver you could check into that.
Me~Jim, 45
DW~Patty, no comment
DS~Dave,20
DD~Megan,18
DD~Emily,12
200lb. English Mastiff~Gulliver,9
2005 Expedition Eddie Bauer
2002 Palomino Stampede 235 SL
popere
Denver
Posted: 08/31/09 06:14am Link  |  Quote  |  Print  |  Notify Moderator
No none knows where to find this piece of rubber? All these hybrids and no one has ever had to change it out?
I even called the dealer that I pruchased my HTT from and they acted like they had no clue what I was talking about they wanted me to take a picture of it and send it to them.
PershingD
Richland, MO
Good Sam RV Club
Posted: 08/31/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Not sure this applies, but its pretty close.
I lost the pad on one of the latches on my Kodiak, but it was more like a hard plastic rather than a dense foam. I went through the same thing as I was looking for a replacement. My wife finally wondered what I was up to and took a look at it. She then when to the cupboard and pulled out a well used plastic cutting board and handed it to me. I cut out a square the appropriate size and used some silicone gasket maker and attached it to the latch. I used the pressure of holding the bunk closed to hold the new block in place until the silicone cured. Works like a charm so far.
David
David Pershing
Gayle-DW
Alex-DS
Jesse-DS
Nikki-DD
1999 Ford E-350 Super Duty 6.8L V-10
2005 Kodiak 23TT - No mods yet, but I'm sure there'll be some!
popere
Denver
Posted: 08/31/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks David, I can't seem to find anything to work so, I may give the CB a try.
Thanks Again
tupfam
Colchester, CT
Posted: 08/31/09 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Try contacting Fastech Industrial (1-800-837-2505). They are a supplier of the latches. They should have the rubber pads that you are looking for.
'02 Ford F150 SuperCrew 5.4L Triton
'07 Gulfstream Conquest 25RSL
popere
Denver
Posted: 08/31/09 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks tupfam, I just left them a VM. We'll see what they come back with.
sjones6335
Dracut, MA
Good Sam RV Club
Posted: 08/31/09 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
If you can't get something from them latch mfg let us know. I have something I use at work that i think should work well.
* This post was edited 08/31/09 07:57pm by sjones6335 *
2005 Chevy Trailblazer LT
2010 Rockwood Roo 19
risingsun
Prescott, AZ
Posted: 08/31/09 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
I asked this question awhile back - here's the thread. I never actually replaced mine, though... They are still pretty flat.
2006 Rockwood Roo 23SS
2004 GMC Yukon SLT
 > Bunk End Latch ?
