RV.Net Open Roads Forum: Can anyone identify what has happened to our wall?
 > Can anyone identify what has happened to our wall?
Page of 5
Travel Trailers Related Tips
JBSummer
Baltimore, MD, USA
Posted: 08/30/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
We were cleaning out our Jayco 30FBS today and I noticed a section of wall between the kitchen sink and the door has scores of little raised "pimples". They are fairly resilient and when I push on them with a fingernail, like the one right of center, it leaves a dent in each pimple. Here's a link to a series of pics of the wall.
http://picasaweb.google.com/WaltWankel/ACampingWeWillGo#5375922476541194194
At first, I thought it might be the effects of mice in the wall (we had a gang of them move in during the winter) but if thats what it was, I would expect the mice to have chewed through. The only other thing I can think of is that this is the side of the trailer that gets the most sun and maybe this is the effect of heat buildup.
Anyone else have this happen to them?
Thanks...
JIM
Big Katuna
Deland, FL
Good Sam RV Club
Posted: 08/30/09 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing adhesive failure of the vinyl covering or possibly delamination of the wall. I would send these pictures to Jayco.
My Kharma ran over my Dogma.
Beaker
Brevard, NC
Good Sam RV Club
Posted: 08/30/09 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
On my Trail lite, it was water damage. Hope I am wrong on yours.
2008 Silverado 2500HD Duramax
1998 23' Jayco lite
fordsooperdooty
Orange Kounty Kalifornia
Posted: 08/30/09 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'd vote for water damage, but maybe in the very most minimal degree. It may be merely condensation in the wall that caused it, not an actual leak. Send it to Jayco Customer Service, call them first...574-825-5861...they will be able to identify it. Does the wall still feel firm?
A Jayco is not just an RV, it's a life choice!
jeffcall7
Southern York County, PA
Posted: 08/30/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
That looks exactly like the wall in which I had water damage in my last camper. No one believes the little raised bumps are from water in the wall, but it certainly was on ours. Start looking around a bit more - maybe peel up the vinyl in a small spot under the cabinets below that area. Sorry.
'09 Jayco Eagle 314 BHDS, Reese Dual Cam
'06 Dodge Ram 2500 CTD 4x4 QuadCab Long Bed
Dennis Henderson
Crystal River, Florida
Posted: 08/30/09 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
You have had water infiltration into the wall and under the vinyl wall covering mold is growing and causing the bumps/pimples. Once you lift up the wallpaper, you will see the water damage and the black mold. Been there, done that.
Dennis and Cindy Henderson
fulltiming, currently at Crabtree Meadows at milepost 339 on the Blue Ridge Parkway in North Carolina
ny_ttd
Upstate, NY
Posted: 08/30/09 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for water damage. I had a similar problem and it was an external water leak.
DAN
Bromley
Mexico
Posted: 08/30/09 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Being in the wallpaper industry for 25 years , definitely water from behind (leak).
50grit
Terrace
Good Sam RV Club
Posted: 08/30/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Stick a pin in one and then give it a little squeeze, if water comes out, better start looking where its coming from, good luck.
thamilton1954
Silver City NM
Posted: 08/30/09 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect the same as the others in the forum. Water damage. Sometimes it happens in houses too. I would think that it is possible that water has soaked the insulation, and that the highest contact points between the insulation and the wall has led to water concentrating and soaking through more in some places than others. The dimpling may be from the areas of most heavily concentrated glue that is holding the vinyl in place. The glue will expand more in some places than others, and cause that dimpling. There is likely to be mold behind it, because it won't dry out easily, and the spores will be able to grow happily in there and probably in the insulation.
Page of 5
