RV.Net Open Roads Forum: Folding Trailers: when mickey mouse attacks
 > when mickey mouse attacks
Folding Trailers Related Tips
ejbrandley
Entirely too young to be a
Posted: 08/30/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
well i just bought a pop up for my nephew's wedding pressent its a 91 arcadia for 200$ well i got it so cheap because a mouse or mice got into it and there is about a dozen holes in the canvas most on the vinyl top side anyone know if a iron on patch would work to fix it till we can gat the new canvas the holes arnt too big and there not close together
Eric
TV 1997 GMC SUBURBAN, 92 Mustang Rag Top
1986 34ft Nomad
Eric 33,Tammi 39,Anthony 14,Julia 12,Jason 11,Briana 8,Ashley 6,Robert 4
mistressofdistress
Obion, TN
Posted: 08/30/09 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Irons and vinyl usually don't go together, you might ask an upholstery shop what to use or maybe just duct tape.
kknowlton
Wisconsin Border Country, IL
Posted: 08/31/09 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Duct tape might work pretty well, depending on the size of the holes. If they're too big, keep a tarp over the bed end when it's deployed.
Guest
Posted: 08/31/09 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
I thought it was going to be a horror story about Disney / Fort Wilderness....
TheHomelessGuy
San Jose, CA
Posted: 08/31/09 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Although mistressofdistress is correct, I have had good experience applying iron on patches to vinyl on my Jayco.
The bunkends have a weak spot where they come down over the ends of the bed slide outs. My front bunk ripped and was replaced by Jayco. The replacement has a second layer of material in those spots, so Jayco must be aware of the problem and changed their design.
But I decided to be proactive with the rear bunk and add my own reinforcing material. I used iron on jeans material patches. A trick recommended for ironing patches onto synthetic material, and a tip from grandma, and it worked just fine.
1) Use a medium heat for synthetics
2) Preheat the patch before applying to the material to be repaired.
3) Only apply from the back side (fabric side)
4) Lay a slightly dampened kitchen towel under the vinyl.
5) Don't leave the iron on too long in one spot.
6) It will take 2 to 3 minutes - check the edges for adhesion every so often.
Don't forget a firm surface to iron on.
HTH
Jim
2004 Chevy Colorado 4x4
Jayco Baja 10Y
Yamaha Grizzly 700FI
I'm like the Roaming Gnome - you never know when I'll turn up on your lawn
ejbrandley
Posted: 08/31/09 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
HTH
Jim
thanks homeless i knew someone would be able to help out
