RV.Net Open Roads Forum: Dinghy Towing: First time to tow - need advice
Search only in Dinghy Towing
 > First time to tow - need advice
Dinghy Towing Related Tips
SaintsFan
Mobile, Alabama
Good Sam RV Club
Posted: 08/31/09 10:13am Link  |  Quote  |  Print  |  Notify Moderator
We just bought a 2000 Saturn LW2. The manual says to just turn the key to "ACC" position, then turn off fog lamps and all accessories, and shift into neutral. Do I need to pull any fuses? Does the beeping eventually stop after turning the key to "ACC"? Is there anything I need to know? This is our first time to tow.
LarrynBarb
NE Kansas
Good Sam RV Club
Posted: 08/31/09 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Have you looked closely at your owners manual ?
I would think that it would be addressed in the manual.
I really can't help you with the specifics on this vehicle, but I am sure that some one will chime in and give you some assistance.
Good luck, Larry
05 Fleetwood Discovery, 39J
07 Ford Explorer, Sport Trac, 4 x 4
Blue Ox baseplate, Ready Brute Towbar w/built
in supplemental surge brake system
FMCA, Good Sam's, Golden Age Passport
Served Proudly US Army 1959 - 2006
fred v.
florida
Good Sam RV Club
Posted: 08/31/09 11:22am Link  |  Quote  |  Print  |  Notify Moderator
the beeping probably quits when you close the car door. it does on my chevy toad. fred
SaintsFan
Mobile, Alabama
Good Sam RV Club
Posted: 08/31/09 11:30am Link  |  Quote  |  Print  |  Notify Moderator
A short time after posting this question I realized I had been playing with this with the door open. I get the "DUHH" award today.
maddog348
Bakersfield,CA
Good Sam RV Club
Posted: 08/31/09 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you don't forget to take parking brake off.
towing_fool
Posted: 08/31/09 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
To set your "SATURN" for towing is generally as follows....
attach your towbar (brand and type at this point is not relevant)
BACK THE VEHICLE AWAY FROM MOTORHOME to lock the towbar...pulling forward with the m/h will cause 1 arm (side to lock) at the minimum but with 1 arm unlocked, the car can come forward (if you stop or turn the motorhome) and the weight of said vehicle can come forward and possibly bend the "locked arm"....so ALWAYS BACK THE CAR TO ENGAGE THE LOCKS....
on the "saturn" your manual will tell you which fuse to pull, but you are correct....turn all accessories off (radio, a/c, nav system,wipers,etc) to the off position...key in accessory since the wheel needs to be free....emergency brake off....transmission in neutral, windows rolled up (keeps car clean) and drivers door unlocked.....
UNLOCKED YOU ASK??? yes unlocked, everyone knows you are towing with the keys in the ignition, car cannot be stollen while being towed, but..... what about if you go eat or take a break???....car can be taken....so when you go anywhere other than inside your RV....remove the keys and lock the door.....
what do you do with the keys?????
did you say put them in your pocket??????
I HOPE NOT !!!!!
you see in order to remove the key, you have to put the car in park...then you locked it right?...then put the key in your pocket you said??? WELL...now we are done eating, we are fat/dumb/and happy when we leave the restaurant or maybe its late or raining or we are distracted...in any case we get in the motorhome and pull away.....BEEP BEEEP BEEEP BEEEEEEP...WARNING !!!! you are about to drive off with the car in park and with the wheel locked......DONT DO THAT !!!
place the key either in the doorway of the motorhome or in the ignition of the motorhome, it may not fit all the way or fit well but it will keep you from starting the motorhome without getting the car "ready again"
hope this helps everyone.... for those of you who have had your vehicles set up by me....already know from reading this, who i am....
good luck, and happy, trouble free towing.
john
John Sanchez
Triker33
Homestead, FL
Good Sam RV Club
Posted: 08/31/09 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Yep! But they don't know the key hasn't had the chip in it programed yet.
After they look at all the 7 locks on the tow bars, steel cables, light cables, air cables, and emergence stop cable to take off.
Don't you think maybe they will look around for a easier car to steal.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
Banks Powerpack
DataStorm SatMax5 | CoPilot Live 10 | VMSpc | Pressure Pro
14' Chariot Trailer
2001 FXSTI HD
08 HHR LT2
Click here to see where I am
jhughd
N MS
Good Sam RV Club
Posted: 08/31/09 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
My tow bar is locked at both ends until I am ready to unhook. Key in or out, still hard to steal.
JD
jhughd
N MS
Good Sam RV Club
deleted
fred v.
florida
Good Sam RV Club
Posted: 09/06/09 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
why would you leave the car door unlocked? I leave key in ignition and lock the doors of my chevy cavalier when i tow. fred
