RV.Net Open Roads Forum: Dinghy Towing: Road noise Jeep Liberty
Search only in Dinghy Towing
 > Road noise Jeep Liberty
Dinghy Towing Related Tips
camper_ron
Raynham, MA
Good Sam RV Club
Posted: 09/02/09 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I own a 2004 Jeep Liberty / Limited with Good Year Wrangler Tires P235/70R16. The Jeep has 24,000 miles on it and the road noise we have experienced seems to be getting worse. We use this car a toad. The tires are cupped and I have just had it lined up. I will be replacing all the tires when I return home but do not want to replace them with the same brand if that is what is causing the problem. The road noise is so loud we cannot drive with the rear winds in the down position.
Thank you in advance for any info regarding this matter.
r0n
Daboo
Texas Panhandle USA
Posted: 09/02/09 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
i was looking into a Jeep Lib...for a toad...I test drove it...did't buy it because of the noise...I have owned two jeep wranglers, and they were good vechiles, but the Liberty seems to be cheaply made...I tow an 05 Malibu ..which is a good vehicle for towing and besides I get about 30 mpg around town with it...
best of luck
Hello from the windy Texas Panhandle
Winnebago Adventurer 33V
Served proudly 1957-1965..U.S. Air Force
TEXAS2STEP
New Braunfels Texas
Good Sam RV Club
Posted: 09/02/09 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem with my toad w/29000 miles on it. I thought the bearings were going. Replaced w/Goodrich, & noise went away.
2007 Fleetwood Bounder 35E
2007 Grand Vitara 4/wd
FMCA
Diplomat Don
Moorpark, Ca
Good Sam RV Club
Posted: 09/02/09 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
camper_ron.....Most tires get louder as they get older. There is less rubber and it begins to harden, making the tires louder. I've noticed that the Goodyears seem to do this more than most.
When you purchase new tires, check the tread wear numbers. These numbers tell you how long they should last. The only issue is that the softer the rubber, the quicker they wear.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
stripit
Clinton Twp, MI
I have a 2007 Liberty with 41,000 driving miles, not towed. Tire noise from cupped tires can be and is annoying. I think that is the noise your hearing. I have rotated our tires every 18,000 miles and rebalanced them. I think by looking at them we can get another 25,000 miles. I personally don't find the tire noise bothersome, but mine are not cupped or wearing funny.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'04 PT Turbo
'Direcway satellite
mike brez
milford ct
Posted: 09/02/09 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Seeing your in MA. and have to deal with snow and ice. General Grabber is a excellent tire. Here is a link to my sons car that we put them on over a year ago.
1994 Pace Arrow 33L Class A 454 P30 2002 F250 lariet crewcab 4x4 7.3 PSD srw short bed auto 3.73 gears,reese 16k slide hitch,reese brake controller ford factory aic,autometer three guage pod trany temp,pyrometer,turbo boost,banks 4inch monster exhaust,aFe air box,sonnax valve and tri springs,magnafine trans filter,Wicked Wheel,TS flip chip 75/100/125/OMG,03 tt heated/signal mirrors,runningboard leds.Other than that its all stock
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
tonkatoys
maine
Posted: 09/02/09 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
have a 05 liberty with 62,000 miles and have had new tires a few times and never have had any noise that you speak of. it came with the goodyear wrangler ST's and have always replaced them with the same. we use it as a toad and the different sets tires had about 85,000 miles. no noise yet.
Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, loudly proclaiming---WOW WHAT A
RIDE!!!
Phillerup
Posted: 09/02/09 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 Jeep Liberty. I tow it also. Bought it used. The dealer bought and put on new Yokohama Geolander tires when I bought it and they have been fine. I had and towed a Wrangler before this Liberty. One of the big reasons I got rid of it was the road noise from the tires, wind noise and such. The Wrangler was so bad that on the highway I could not hear the radio. The Liberty has been great. Cupped and worn tires will cause a lot of noise. Some people rotate 4WD off road tires same pattern as they do street tires and this should not be done IMO. That can also cause a noise. Replace the tires and I bet it will go away. The Liberty is not my daily driver but it has been a great and very dependable little vehicle. I have not had to do ONE thing to it except regular routine maintenance like oil changes. I don't notice a tire noise that is annoying. Until I read your post I never thought about a tire noise with it.
2003 Newmar DSDP 4005 dual slide king bed Spartan 350 Cummins 2004 Jeep Liberty 4X4 tow, SeaEagle boat in basement
fourfurz
Memphis
Posted: 09/02/09 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
We had the exact same problem with our 2006 Jeep Rubicon, the solution was easy. We jacked up the gas cap and drove a 2006 Honda CR-V under it. Very quiet, very low rolling resistance, 25 mpg and more room inside. Also, the best A/C I've ever had in a car.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
chastho
arkansas
Posted: 09/02/09 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Go to tirerack.com and look at the kumho tires, I put them on my Saturn vue and really like them. 85,000 mile tread warranty and the highest customer satisfaction rating.
