RV.Net Open Roads Forum: Toy Haulers: Trailer Tire Advice
Search only in Toy Haulers
 > Trailer Tire Advice
Toy Haulers Related Tips
matthewc66
San Diego
Posted: 09/03/09 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Fuzion that came with the 15 inch Mission Tires.
I don't drive a lot of miles so I am not sure if I should upgrade to 16 inch rims or just stay with the 15's and get E rated tires.
I went to Discount Tire as well as Camping World and they had Goodyear Marathons.
I asked for the Michelin XPS Ribs but no one can find them in 15 inch?
Any advice would be appreciated.
I am in North San Diego County.
George H
Washington
Posted: 09/03/09 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
US made Marathons are supposed to be OK. Do not accept Chinese made may pops.
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
smkettner
Good Sam RV Club
Posted: 09/03/09 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Is the wheel rated 80psi? Even 75 psi would allow the E to be an improvement. Look for a stamp on the back.
Google XPS Ribs and you will find they are only made in 16"
I would go with the 15" E if you can get some additional pressure. Since you are not having trouble there is no reason to overkill on this. Driving lots of miles I think is better for the tires. Going out only twice a year is harder on the tires IMO.
Chuck&Gail
In the Colorado Mountains
Posted: 09/03/09 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
My only advice is to be careful of your WHEEL rating. Most wheels I've seen are rated for the stock tire size. So if you "upgrade" to a higher load range you might very well be overloading the wheels. Not a good plan. Most wheels have numbers stamped on rear, or under tire in valley. So, what is the load range on the stock tires? What is the rating on the wheels?
Do figure if you need to change load range. What is your ACTUAL MEASURED fully loaded trailer weight? What are the AXLES rated at? That is the place to start the decision process IMO.
Maxxis makes 15" in various load ranges, and has a good reputation. Mine are made in Thailand, not China.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Are_we_there_yet
California
Posted: 09/03/09 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing on my toy hauler. I had 15" D load range tires that were showing ozone cracking and wanted to upgrade the new tires. One thing that was pointed out to me was that if I went to 16" tires, the space between the tires would be less, possibly causing problems. I decided to stay with 15" but went to an "E" load range. The one "problem" I encountered was the new tires require 80 psi for max load (2,830 lbs); the rims are stamped that they are rated for 2,830 lbs but they showed max psi as 70 lbs. I didn't change the rims. My trailer max weight is 10k lbs due to 5,000 lbs duel axles.
Turbo Diesel Dude
Green Mountain, NC
Good Sam RV Club
Posted: 09/03/09 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I went from ST205 75R15 D Maypop Marathons (one did pop) to Maxxis ST 225 75R 15E. In my opinion the wheel can take the added 15 psi and has to date survived without a hitch.
charles weidman
Dick_B
Palos Heights, IL USA
Good Sam RV Club
Posted: 09/03/09 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Our camper came with 15 inch tires but we were able to upgrade to 16" Michelin XPS Rib's.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
MegaDodge
Ontario, Canada
Good Sam RV Club
Posted: 09/03/09 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Don't load the Marathons any heavier than 2000 lbs each. They say 3050lbs...but a Discount Tire dealer told me, no more than 2000 lbs because they can't take it. I had them on my Everest and had nothing but trouble, blowouts, delaminations. I went to XPS/RIBS and the problems stopped.....BUT...check your rims to be sure that they can take 80 lbs pressure. AND....be sure the tires will fit if you go to 16" Mine are close..about one inch apart...dealer said that was not a problem...and it has not been a problem. The space got smaller because the tires are higher than the Maypops.....willpops...??
MegaDodge
Dodge CTD 1 ton. 5 speed.
2003 Everest 323P 5th wheel 13000 pounds ready to roll. .
"An honest man is the guy who does the right thing when nobody's looking"
boiledcrabs
louisiana
Posted: 09/03/09 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I got a good deal on some Michelin XPS ribs from a place called Tire Kingdom. I don't know if you have them there but the price in the store was less than ordering them online.
AIR ASSAULT 18B
Oregon
Posted: 09/03/09 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Bite the bullet & go with the 16in wheel & LT tires. After 3 sets of 6 Mission/Freestar replacements I went with the Eagle 16x7 wheel & BFGOODRICH Commercial 245/75/16E tires. I just returned from a trip from Oregon to Crazy Horse-Rushmore-Devils Tower & back. No problems at all & it seems to pull smoother & less bounce from the Raptor 3814. At just about every campground,truckstop or reststop I saw various RVs with mismatched tires multiple spares mounted with destroyed tires & wheels & of course the wheel well area of the rv blown out. I dont know where you travel but if you get stuck with bad tires & wheels on some of the legs I traveled there are no services or cell coverage for several hours & hundreds of miles.The Michelin XPS are also a fine tire. This is the first trip where I had total piece of mind & confidence with my tires & wheels.
2002 Chevy 2500HD D/A 4X4
2007 Raptor 3814
2006 Kawasaki Brute Force 750
2001 Honda XR650R
