RV.Net Open Roads Forum: Fifth-Wheels: grease bearings
 > grease bearings
Fifth-Wheels Related Tips
Prin
Central Ohio, USA
Posted: 09/06/09 08:11am Link  |  Quote  |  Print  |  Notify Moderator
It is time that I grease the bearing on my Cameo. I have the dexter type with the grease fitting. What type of grease do I use? Is there a compatability issue? I understand that I don't need to add much grease at all. This is my second season on the unit and it has about 3500 miles on it. Any adivice?
thanks,
Ted and Carol
2008 Cameo RE373S
Chevy Silverado 2500 HD Diesel
Yamaha 2400i generators
Goldwing Motorcycle
Retired Educators
mpfireman
Cook County Il
Posted: 09/06/09 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Depending upon the miles you put on your unit each year, it is a good practice to grease the wheels every year, at the start of you're camping season. If traveling many miles, like over 5000, I grease the wheels during the trip. Yep, do not over grease the wheels, just a few 2 or 3 squirts from the grease gun is all it needs. Some pull there wheels every few years to check the condition of the break shoes, not a bad idea. I use synthetic grease when doing mine, read the information provided with the grease. When I replaced my brakes on my fiver, it had traveled for 11 years and over 45 thousand miles. I replaced the WHOLE brake assembly as it was cheeper and better than just replacing the shoes.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
Cox89XJ
Tennessee
Posted: 09/06/09 09:33am Link  |  Quote  |  Print  |  Notify Moderator
After finding a leaking seal on my previous camper. I repack mine by hand. I've read on here some jack up one trailer wheel at a time and rotate the wheel while greasing that bearing. Sounds like a good idea if you are going to use the grease zerks.
Mont G&J
Missoula, MT
Good Sam RV Club
Posted: 09/06/09 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Click the following link to Dexter Axle EZ lube grease type and manufacture. EZ LUBE GREASE Jack
kschitoskey
Albuquerque, NM
Posted: 09/06/09 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Many make the mistake of just adding add'l grease to the zerk in lieu of repacking the bearings. I repack every year; gives me a chance to grease the suspension, inspect / adjust brakes and go over the bearings thoroughly. The first time I did them, there was an enormous amount of grease between the bearings - the previous owner only added via the zerk. Too much of a good thing...
07 Keystone Cougar 289BHS - 16" Commercial TAs, Trailair Equa-flex, Steady Fast
06 Dodge 3/4 T Mega Cab 5.9 ISB - Pacbrake air bags, B&W Companion
Puddles
Lafayette, Indiana
Posted: 09/06/09 10:35am Link  |  Quote  |  Print  |  Notify Moderator
If the seal fails... you're greasing your brake shoes.. why risk it?? pull the wheel and hand pack for me...
HTML
JFG
TN
Posted: 09/06/09 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I use the zerk fittings and have never had a problem... just follow the instructions... I use Mobile 1... the red stuff.
Fred
rbell
Mi
Posted: 09/06/09 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I inspect them once a year, replace the seals, & pack them. Every once in a while I'll add some using the zerk fitting.
BTW I use Kendall Super Blue grease. It comes in a small tub & a tube for your grease gun.
Dick
Hannibal
Gas Station
Posted: 09/06/09 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
With grease being thick, it's important to pump the grease in slowly so the old grease can ooze out of the front bearing without creating pressure on the seal at the rear bearing.
'05 2500HD Dodge SLT RB1 5.7L Hemi 5spd auto/4.56. 119k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins
'07 KZ Jag 28JFSS.
Gunpilot77
Killeen, Tx
Posted: 09/06/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
If you only add a couple of squirts at a tme you will die of old age before the outer bearing gets any new grease. The hub has to be completely packed with grease before the outer bearing gets any. You decide if you want to gamble that the inner seal will hold or that it isn't worn enough to allow the grease to get to the brake linings. If your plan is to purge the old grease out compatability isn't an issue. Should only take about two tubes to do the job.
Fifth wheel pulled with a pick-up
 > grease bearings
