your friend
Pennsville, NJ
Good Sam RV Club
I just bought a new coachmen catalina and have used it for about two weeks. It has a slide out that has a tarp covering on the bottom. After sliding it out this past weekend I noticed that the tarp covering has started to seperate and come loose from the bottom of the slide out. When I returned home I slid the side out to clean and now the tarp is completely loose and actually hanging down now. I have called the dealer and plan on taking it back to them needless to say I am very upset with this. Has anyone had this happen? Will they have to take the slide completely out in order to fix this problem? Thanks for your help.
TV: 2006 Nissan Titan
TT: 2010 Coachmen Catalina
old guy
Oregon (pronounced Or e gun)
sound like to me the tarp was installed too tight and every time you let out the slide it goes past it's point of tearing and now is completely undone.
smkettner
Good Sam RV Club
Mine has no cover on the bottom.
your friend
Pennsville, NJ
Good Sam RV Club
smkettner wrote: Mine has no cover on the bottom.
That is something that has come to mind I thought about just taking the cover off but I stop short because it came with the cover in tact. I feel if it came with the cover it shoudl always have one that is why I want to dealer to look at it and fix it. I am just not sure. I am hoping that the dealer doesn't just suggest cutting it off and that's it. It is a brand new trailer and I don't think it should have this problem. I don't think it is from anything I did wrong. I just slid the thing out and in...isn't that is what it was made for???
chevyman2
missouri
old guy wrote: sound like to me the tarp was installed too tight and every time you let out the slide it goes past it's point of tearing and now is completely undone.
That is my thought exactly. I do agree in taking it back. It is a new trailer and it needs to go back. However if it was a few years old I would likely cut it off and forget it.
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 94 TRANS AM (DA TOY)
When I grow up I want to be retired.. THEN I WONT HAVE TO GROW UP AT ALL!!!!
JJBIRISH
Butler, PA, USA
Good Sam RV Club
tarp??? do you mean the under belly material???
Love my mass produced, entry level, built by Lazy American Workers, Hornet
doubleclutch2009
somewhere in the lower 48
Had a fleetwood that did the same thing. Get it fixed is my reccomendation. Didn't fix mine and the cheapo plywood floore delaminated and rotted out. On the plus side, I got rid of the trailer after only 2 years and went with a holidar rambler. You guessed it! I am not a fleetwood fan
your friend
Pennsville, NJ
Good Sam RV Club
JJBIRISH wrote: tarp??? do you mean the under belly material???
No it is not the underbelly it is just under the slide out. It is an actual tarp material.
Bucky Badger
Madison, WI
your friend wrote: I have called the dealer and plan on taking it back to them needless to say I am very upset with this. Has anyone had this happen? .
If that is the only thing you found wrong...You are lucky. Don't get upset over the little things that can be fixed.
Fred & Jodie, dogs, Zoey & Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
http://banners.wunderground.com/weathersticker/gizmotimetempbig/language/www/US/CA/Carlsbad.gif
Rallies/Gatherings
IL
WI
