RV.Net Open Roads Forum: Tech Issues: Help - A/C Problem?
 > Help - A/C Problem?
Tech Issues Related Tips
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/08/09 05:59am Link  |  Quote  |  Print  |  Notify Moderator
Seem to be having some sort of A/C problem.
A/C will run and blow cold air, but sounds pretty loud and seems to be struggling.
This runs on shore power and will also run off the genny, but seems to bog the genny down. At some point it actually stalls out and kills the genny. It has popped the breaker at the breaker box and even the 12V breaker in the engine compartment (shutting off all 12V accessories in the rig).
I went up on the roof and removed the A/C shroud but nothing looked overly dirty or clogged.
I hate electrical and no clue when it comes to the A/C.
Any suggestions on troubleshooting (to save a trip to a dealer) would be greatly appreciated!
* This post was edited 09/10/09 05:00am by NAUTIQUE *
Our Portable Summer Cottage II : 2000 GBM LANDAU on 1999 F53 chassis
Sumitomo ST718's,Bilstein's,Steer-Safe,UltraTrac
& Aventa II pulling a 97TJ
- Pics & Mods * GBM Thread * F53 Thread
The Crew: Lovely Wife,2 Daughters & Springer Spaniel!
LIFE IS GOOD!
stevesandidge
kingsport tn
Posted: 09/08/09 06:05am Link  |  Quote  |  Print  |  Notify Moderator
sounds like you need to check the quality of your power from the genset. i use the good govener that i got a camping world that plugs into an outlet and tells me the voltage and frequency of what my power is. otherwise you will need a meter, and it sounds like you don't have one.
steve
steve sandidge
RVIA certified rv tech
camping world rv university
class 54
fix-it rv service
USMC 1982-1994
91 holiday rambler imperial 37'
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/08/09 07:25am Link  |  Quote  |  Print  |  Notify Moderator
steve
Steve,
I think that I can check it out tonight.
My dad's better with electrical than I am and he has one of those dial test meters with the black & red probes.
I'm assuming to check this, I'd start genny, let warm up, get a reading from an outlet, start A/C, get another reading from an outlet??
* This post was edited 09/08/09 01:28pm by NAUTIQUE *
Handbasket
Asheville, NC
Posted: 09/08/09 07:38am Link  |  Quote  |  Print  |  Notify Moderator
You may get better answers if you state what size & brand of A/C and generator you have.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison ('Loafer's Glory'); '07 Forester 2.5 ( the 'HANDBSKT'); '95 Toyota SR5 V-6 4x4 pickup, ARB locker, Bilsteins, Warn hubs & M8000, etc;
'94 968, M030 swaybars ('DOPPLER')
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/08/09 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Jim, "Mo' coffee!"
You're right Jim!
Onan Emerald Plus 4000 & a 15,000 ducted Duo-Therm Quite Cool.
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/08/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Ok - Checked out the volts at the kitchen plug:
Plugged into stick house (20amp)
115-118 volts & then 102-105 volts when A/C is turned on.
Plugged into Genny
131-135 volts & then 126-128 volts when A/C is turned on.
A/C blows cold air, but just sounds like it's straining/surging?
MI Director
Michigan
Good Sam RV Club
Posted: 09/08/09 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
That's volt from the house is too low when the A/C is on. Should be no lower that 105 or you'll be do damage to your equipment.
The genny is too high with no load and should not be over 130 volts max.
Might have a run cap going bad on the A/C.
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/09/09 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Run Cap?
Any suggestions on where I should go from here?
Trip to a service person?
NAUTIQUE
SOUTHEASTERN MA.
Good Sam RV Club
Posted: 09/09/09 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone think that taking a shot at the Hard Start Capacitor MOD would be a possible soloution to this problem??
MrWizard
Van Nuys, Ca
Posted: 09/09/09 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
I think with a 15k btu A/C and a 4kw generator, you are on the ragged edge with the genny, any extra 'high heat', 'high load' re-start on the A/C compressor is pushing the Onan pass its max capability
pour several cans of 'sea foam' engine cleaner into you gas tank, and put a suppco hard start kit on the A/C compressor, and you might want to put the A/C on and leave it there and turn the it to med or low but leave it run full time ( not cycling ), IF your A/C cycles on/off without a fan cycle to lower head pressure on the A/C compressor it is going to cause extreme peak surge currents that the 4kw can't deliver.
Connected via Verizon Via Motorola Droid with Android2 OS
