RV.Net Open Roads Forum: Tow Vehicles: Changes for 2010 SuperDutys
Search only in Tow Vehicles
 > Changes for 2010 SuperDutys
Page of 6
Tow Vehicles Related Tips
SoCalDesertRider
SanDiego, CA, USA
Posted: 09/10/09 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
If you knew what the number meant, you would clearly see the thing is geared way too high and that 6 speed makes the gearing even higher, not lower.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
RB70D
Oregon, WI
Posted: 09/10/09 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
I think the fact that the new diesel is made in Mexico would be enough to turn me away.
Rich & Sheryl
1997 Peterbilt 385
210" Wheelbase, Cummins ISM 400 hp, 3.70 ratio, Super 10
1997 Avion 38'
TrailerSaver
RollingRockTX
Keller, Texas
Posted: 09/10/09 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Well, You can have a Fiat, or a Government Motors or the only truck who didn't take or need bail out money but with a new engine assembled in Mexico.
I take the latter ANY day.
2006 Ford F250 King Ranch PSD
2008 Ford Expedition, HD Tow Package
2005 Chrysler Pacifica, GONE!
2008 Jayco Eagle Super Light 31.5BHDS, KC5PFG,
5th Airborne with SideWinder, Plugitright Stabilizers.
hypoxia
Arizona
Posted: 09/10/09 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Capt Skup wrote:
I am really surprised with those that stated that they are disappointed with the power output of the 6.4 in the Superduty.
Hey Capt, come to AZ and drive mine. You'll be dissappointed also. Sure does a great job with no load though!
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
bimbert84
MI
Posted: 09/11/09 04:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure I see the problem. If the final drive ratio is higher than you want at any given time, just drop to the next lower gear.
-- Rob
2003 Ram 1500 QC 4x2, 5.7L Hemi, 3.92 (GCWR=14000, GVWR=6650, WB=140")
2004 Springdale 295BHL, 31'5" (DVW=5800, UVW=6200, GVW=7400)
Hensley hitch, Prodigy controller
Capt Skup
Southern Maryland/Nantucket
Posted: 09/11/09 05:32am Link  |  Quote  |  Print  |  Notify Moderator
If you "feel" that your 6.4 is underpowered towing a 31 foot fifth wheel, I recommend that you pay your dealership a visit. Have you changed the fuel filters iaw the maintenance schedule, drained the water seperator monthly? Reason I ask, I towed almost 32,000lbs combined up 8% grades at altitude and never felt the truck was underpowered or struggled with the load, maintaining a decent road speed the entire climb. I suspect something is amiss with your truck.
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
'08 F-450 Lariat 4x4
'08 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
hypoxia
Arizona
Posted: 09/11/09 07:02am Link  |  Quote  |  Print  |  Notify Moderator
bimbert84 wrote:
If the final drive ratio is higher than you want at any given time, just drop to the next lower gear.-- Rob
Doesn't work that way, there are more gears in the transmission than on the selector and the computer decides what to do regardless of where you place the selector.
Once the territorial Ford rep puts a data recorder on the truck and takes it for a drive with my trailers in tow I don't think there's much room for argument. The engineers look at the data and say it's doing what it's supposed to do. I have 3.73 gears, what do you have? If you have the 4.30 or 4.88 you are rated for 29000 or 33000GCW respectively. I'm rated for 23000 GCW and that's what it weighs. Am I happy about it? No, but as the engineers said, trade it in for what Capt Skup has, an F450 will do the job! BTW all of your filter suggestions were done prior to the rep taking it.
ib516
Up here!
Posted: 09/11/09 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Cummins (made in the USA) is a Fiat?
2004 Cougar 301 BHS
"MEGACASPER" 2007 Dodge/5.9L Cummins/3500 SRW Megacab/48RE/4x4/3.73/10,100# GVWR
RV and truck weight = ~20,000#
Hypertech Max Energy
CLICK FOR NEW PICTURES
ELIM 3000 Generator
GO #88!
BOOOOOOOOOO 55 & 44!
ib516
Up here!
Posted: 09/11/09 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Maybe Capt hasn't heard of the EGRTA defuel issue taht effects those that pull heavy in hot weather....
Capt Skup
Posted: 09/11/09 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I don't know how you would label a Cummins. American made? I read that most of the internals are sourced from Cummins factories in India. I am not knocking Cummins, it is my engine of choice when I purchase the next boat.
Page of 6
