dadd45
northeast NEBR USA
If the water inlet were to be installed I would think the LEAST one would do is GLUE the cover shut and label NO WATER INLET....IMHO, of course
DadD45
2004 Cross Country Coachmen
2001 Wrangler behind
JUST HAVIN' FUN!!!
Yardvarkers
NC
My lawn mower picked up a rock and punched a good sized hole in the outer skin. After a little thought I decided to install another vent cover over the hole since there was one below the hole the mower made. First I straightened out the siding as much as I could. Then covered the hole with foil duct tape. Then installed a vent cover similar to the other one.
2000 Jayco
skipnchar
Topeka Kansas USA
I would CERTAINLY not be making the hole bigger to install ANYTHING to cover a hole. fix the hole itslef should be pretty easy. Even a tin can lid properly shapped and painted would be hardly noticable and wouldn't involve make MORE hole than you already have.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
mxsjw
Washington
Good Sam RV Club
Cut up a beer can and caulk it on...paint to match if you're so inclined, but personally, I'd leave it label out.
2003 Layton Skyline 196LT
2007 Toyota Tundra
JOHNNLISA
VA
Eternabond tape then a sticker on top of the tape if you think it may need a little more cover up. Water proof, flexible and the perfect size (when cut).
www.eternabond.com
Happy Trails
hookie
Naperville, IL
I went to storage last weekend to work on the TT, among other things, to apply eternabond on the roof at various places. To my surprise, I found a HOLE IN THE SIDING! Yep, it was a jagged hole about an inch by a half inch. I decided to cut the right size eternabond and apply. It's near the top, so it's not too noticeable.
Since your hole sounds like it is a bit bigger, I'd try to re-enforce it from the back and then apply eternabond.
Or, pick from one of the many great suggestions already mentioned...
'00 Sunline T-2753 Travel Trailer
'04 GMC Yukon XL 2500, 8.1, 4.10
Hensley, Prodigy
GuyM
The Great Midwest
Caulk it and cover with a blank electrical box cover painted to suit.
Guy
Old Blue
New York USA
Go to a RV store and get a round louvered vent cover..really these are made for a slight problem,,fill the hole with caulk, caulk around the round vent, put in the two screws..and you are good to go..I have seen these vents white or aluminum, probably could paint to suit the camper..I have used these a couple of times and they just look like a vent for something..I think the vents are either 3 or 4 inch//
Good luck
Bill
Bill
36 Holiday Rambler
Harley Rider
mobilefleet
ga
To me, sounds like a great place for a stick on reflector from walmart for 2-3 bucks in the lighting section/automotive
JayWalker2009
w00dsman wrote: downtheroad wrote: How about covering the hole with one of these? (water inlet) Inexpensive and it will look like it belongs there. Caulk and get on down the road....
Hmmm, and then somebody else hooks a hose to it and turns on the water and
w00dsman
I think one might assume that the person who suggested that would figure anyone doing this for cosmetic reasons would inform anyone else who might use the camper and also if anyone else bought it. Not sure why some would assume that the person who suggested it did so in any attempt to dupe anyone as in if it was sold in future...
