Bill and Kathi
SW GA
Okay, I'll try to keep this brief. Our toad is a 2003 Jeep Grand Cherokee, two wheel drive and it doesn't have positive traction nor does it have a limited strip rear end and is pulled with a class A. We haven't noticed the noise while being toad - although it may be there and we just haven't heard it. (We haven't used the motorhome much this year. We're a little nervous about taking the toad very far but the noise has been going on for about a year and a half.) It is only noticed when we make sharp turns and then it sounds like metal hitting metal. I've had it in the shop three different time and had new axle bearings put on, checked the axle and rear end. There is no metal debris and no wear and tear. Some days the noise is worse than others. (We even considered that the weather made a difference??)Sometimes I think the wheel or rear-end is going to fall off. It is so loud it gets people's attention on the street.(Rather embarrassing.) I'm told it is road worthy but I want it fixed. Has anyone else had a problem like this and could it have happen in the towing? Any help would be appreciated.
Thanks
Bill and Kathi
Bill, Kathi and Toby (the doxie) - for the "pitter patter" of little feet in the house.
Love the "Sound of the South" and TSU tailgating. (It's just TU now.)
2004 Damon Intruder 373
Workhorse/5 speed Allison
2002 Jeep Cherokee Toad
towing_fool
You said the Jeep is 2003 and 2wd and that you are towing it???? hummm
you did not mention if the transmission was manual or automatic?
if its manual and 2wd then it is towable (these vehicles are very rare) if it is 2wd and auto...then it has to have a driveshaft disconnect, and if installed incorrectly it will have a noise at the very least. the other posibility is that it in fact is limited slip and not standard rear end...lift the car at the rear, both wheels off the ground, blocked and chocked for safety on level parking lot.... rotate either wheel in the forward direction.....what direction does the other wheel spin in....the same direction= posi or limited slip , no rotation or reverse rotation on the other side= regular rear end...grab driveline and rock it in circular motion clockwise then counterclockwise....there should be only a VERY slight amount of free play....excessive free play can mean you have a carrier bearing problem or mis aligned input shaft free play...get that checked out!!!
hope that helps.
john
enblethen
Moses Lake, WA USA
Good Sam RV Club
Your limited slip differential is toast.
Bud
Suzuki XL7 pushing Pace Arrow
targaboat
sulphur springs, tx, usa
Heed the opinion of the "fool". I doubt that it is towable and you are very fortunate that you have not had more problems.
Fly Boy
Bumpyroad
Virginia
targaboat wrote: Heed the opinion of the "fool". I doubt that it is towable and you are very fortunate that you have not had more problems.
but he asked here and somebody said, "sure it is towable, I towed mine 350,000 miles and didn't have a problem. ".
bumpy
enblethen
Moses Lake, WA USA
Good Sam RV Club
The '03 towing guide at Motorhomemagazine.com says no to 2wd towable,, or at least it isn't listed.
The problem though sounds like it is the limited slip differential and not the transmission.
dicknellen
Northern Nevada, USA
Two Wheel Drive Jeep Grand Cherokees are not towable without modifications such as drive shaft disconect.
Deen
Vancouver, WA
Good Sam RV Club
OP, that doesn't "sound" good! As I remember none of the two wheel drive automatic GC's were towable.
Our GC was full time four wheel drive (Quadra Trak) with the off road package and towed fine for many 1,000's of miles.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor and Recruiter
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
52nd yr of RV'ing
RicJones
So. Cal.
Have you checked your U joints??
gmanatl
Hiram, GA
Good Sam RV Club
I tow a 2000 Jeep Grand Cherokee 4X2 automatic with a drive shaft disconnect behind my class A DP. It doesn't make any strange noises after 10,000 miles. Sounds like your drive shaft may need to be balanced or the u-joints are bad.
