mytime
Winter Snowbird-somewhere
I just installed a receiver in the MH and my TV picture is in Black and White, I had it hooked up in the house and it worked fine there, now when I put up the antenna everything is fine, color picture., what is wrong? I have a 311 receiver and a sharp (aquos) tv, I think that is how you spell it. I have not called dish as I think it is something else, and I have the Trac-star dome sat. Thanks for any help, Marvin
2007 Country Coach, Allure 470, 42',ISL Cummins 400, 2008 Trailblazer TV, Blackhawk and Brakemaster.
hotrod4x5
Southern Calif
Good Sam RV Club
I am confused. You say it works in the house. Then in the motorhome it is black and white, but when you raise the antenna, it turns color. What antenna?
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
PRT
NY~FL
I think it means it only is in color if the batwing antenna is up - where you would think the dome satellite should do it. Not sure if that is a Dish problem.
Pat
May the road rise with you, the wind be always at your back.
lawaco12
gallatin tn
check tv setting. go to menu scroll down to advanced. scroll down to monochrome and be sure that it is off. i have had dish for 12 yrs and just bought a new sharp and had same problem.
Danny Joe
Tennessee
The problem is in the Sharp. I don't remember where but there are settings, I think under digital. Keep looking.
Danny
Fleetwood Bounder
Dodge Van. Ford Auto
2 Min Pins.
mytime
hotrod,
I probably should have been a little plainer, when working off the dome satellite, everything is Black and White, when I raise the local antenna, it works fine, in color...
Thanks to everyone who posted, I too think it is in the TV, I went thro the menu searching but maybe I did not check far enough, I will go back thro that again. Thanks again Marvin
hotrod4x5
Southern Calif
Good Sam RV Club
Ahhh, so the local channels are in color, but the satellite feed is black and white. I get it now.
John&Cathy
Climax, NY
Marvin,
If you are using the "S-Video" input, you may have a bad cable or bent pin.
John - kc2rxs
mrdave
Riverside, CA
Good Sam RV Club
What imput to the tv are you using for the dish?
Color is the first to go for a bad connection when using coax. If it is not the coax (ch 3 or 4 input) than it is one of the components. The satellite box or the TV.
Easiest way to trouble shoot is to replace the TV with anonther one. But be sure to use the same hookup.
larry barnhart
wenatchee. wa usa
Are you turning the antenna's power booster off?
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
