RV.Net Open Roads Forum: Class A Motorhomes: Napa air filter????
 > Napa air filter????
tonkatoys
maine
Posted: 09/15/09 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
have a 04 fleetwood w-22 8.1 engine and need a air filter. i bought one a couple years ago from napa and went back there and they told me they have no listing for the above m/h... anyone use the napa filter for the above year and maybe knows what number filter it is.
if need be i will have to crawl under there and take the old one out, just thought someone would know here before i do that.
thanks
Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, loudly proclaiming---WOW WHAT A
RIDE!!!
dawgs3
n.c
Posted: 09/15/09 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
i have all my filter,belts,etc written down in a book,when it comes time to change i have all the onfo right there.
KOG
Winterville GA
Posted: 09/15/09 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Try one of the other parts stores. Advance carries Purolator stuff which is about as good as it gets. Or find a truck parts store which will have a listing, often for Baldwin. And you can look up the part number on the web by going to a filter manufacturers website.
rgatijnet1
Good Sam RV Club
Posted: 09/15/09 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Check and see if the air cleaner used is the same one as the Corvette, for the same year. Just measure the size and then see how the Corvette element sizes up. I know that mine is the exact same element, but yours may use a different filter box.
moparmaga2
Posted: 09/15/09 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
If it is anything like a Ford chassis, then I just go down to Oreilly and tell them that I have a F-350 V-10.
I would try telling them you have a Chevrolet 3500 8.1, and I bet they come out with the right filter.
2000 National RV Tropi-Cal 37 ft Double Slide Ford V-10
1994 Toyota Celica on a Master Tow Dolly (40 MPG)
The Moparmaga guide to cheaply living in a RV while attending College
CurtisG
Vinton, Louisiana
Good Sam RV Club
Posted: 09/15/09 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
On my 8.1 GM in my '03 Allegro Bay, the air filter is an ACDelco--A1236C or a Wix--46316, maybe yours will be the same. Hope this helps as most parts houses can cross either of these filters to whatever you want.
Curt
CurtisG
2003 34' Allegro Bay
WH(W22)/GM8.1/Allison
suchristo01
San Diego, CA
Posted: 09/15/09 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
2000 7.4 L uses air filter A1236C = WIX 46316 = Napa Gold 6144 The last Napa Gold I tried to replace was not of good quality and would not fit the housing.Put the NAPA Gold 6144 that was in there back and when I got across country put in a WIX 46316 because my nephew worked for an Onan service center and got it for me at his cost and gave it to me.
Tommy USMC,Susie USN Ret, Dog Buddy
2000 Fleetwood Flair 25F WH P32 7.4L 19.5"
2002 Ford Ranger XLT 3.0L 5 Spd Man
Blue Ox Base,Aventa II,4 PIN Locks
US Gear UTB, Power Gear Man Lev, Onan 4KW
Tent,GP Tent,Tent Trailer,2 Class A's
Are We There Yet?
22%Over
Denver, CO
Posted: 09/15/09 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
AC Delco is A1236C, WIX is 46316, NAPA Gold is 6316. The Napa 6144 is NOT the same filter/application as the WIX-46316 ! That is probably why it did not fit.
Drop the first digit off of WIX part number and you have the NAPA part # for filters.
suchristo01
San Diego, CA
Posted: 09/15/09 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
22%Over is absoultely right. I have no idea where I got that number. 6316 is written in my manual,6316 is what is sitting on the shelf. The one that didn't fit had 6316 stamped on it and the one that came out was a 6316. Glad you caught that. Thanks! I have changed more often due to the ash and debris from the numerous devastating wild fires we have had to deal with the last few years.
