eddd
Los Fresnos, TX
The Dometic frig thst came with my camper has a thermostat adjustible from 1-7, but I need to know which is cooler...the higher number (7) or the lower number (1). I guess you can tell I don't use it very often.
2002 Chevy HD2500 4x4 ExtCab LWB D/A
2000 Lance 835
2004 Cannondale F600
1996 BMW R1100RT
1996 Yamaha TW200
milo
4 Corners ....
Good Sam RV Club
Did your fridge come with a manual? It should tell ya.
Milo & Ottis (Mrs.) 33 fantastic yrs together
Both Retarded teachers (oh! I mean retired)
1 Beagle & 2 Aussie Pups (Mother & Daughter)
2004 F250 6.0 PSD CC
2007 294RLS Cougar TT (the Summer Hogaan)
wolfe10
On our Dometic, the higher number is COLDER. But as milo suggested, your manual is your guide.
If you don't have one, Dometic website has copies of the manuals.
http://www.dometic.com/enus/Americas/USA........Support/Operation--Installation-Manuals/
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
MTTitan
Salt Lake City
Can't give you an accurate answer to your question but can suggest a hopefully helpful hint for future accurate monitoring of your refrigerator interior temperature.
Go online and order a basic weather monitoring system such as those from La Crosse Technology that has a small, battery operated remote sensor (or two) that gives you temperature readings and place one of these sensors inside your refrigerator so you can determine the actual temperature (digitally displayed) without opening the fridge door. The one I have cost about $20 with one remote (another remote for outside temp monitoring additional $12) has made my monitoring of refrigerator temperature so much more easier.
2004 Titan LE w/tow pkg
2006 Pioneer 180CK
abrasv
Troy, Mo.
Good Sam RV Club
Higher number on a dometic is colder.
eddd
Los Fresnos, TX
I have the manual, but it says the settings are adjustable between "Max" and "Off No mention of the numbers. (Go figure!) I'm on the move right now in Montana, and the outside temperature varies so dreastically I can't get a good idea of what is going on.
Dutch_12078
Great Sacandaga Lake, NY
MTTitan wrote: Can't give you an accurate answer to your question but can suggest a hopefully helpful hint for future accurate monitoring of your refrigerator interior temperature.
That's what I was using, except an Acu-Rite instead of a LaCrosse. Now I'm using a "Chaney Wireless Refrigerator/Freezer Thermometer" that I bought on eBay for $28 incl. shipping.
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
MTTitan
Salt Lake City
Quote: "That's what I was using, except an Acu-Rite instead of a LaCrosse. Now I'm using a "Chaney Wireless Refrigerator/Freezer Thermometer" that I bought on eBay for $28 incl. shipping."
Thanks for the link to a better unit than I was using. Will consider upgrading.
kaydeejay
SE Michigan, USA
eddd wrote: The Dometic frig thst came with my camper has a thermostat adjustible from 1-7, but I need to know which is cooler...the higher number (7) or the lower number (1). I guess you can tell I don't use it very often.  Start it at "4", that's halfway no matter which end is higher or lower.
Once stabilized you can raise or lower it a notch and see what happens (you will need a thermometer to measure that accurately)
FWIW, my Dometic has a range of 1 to 5, with 5 being the coldest. I run it at "4".
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
