smjanes
Ottawa
Well, I went to top up my Trojan 6V batteries last night in the dark (using a flashlight to see) and accidently overfilled one by about 1/8". Can I remove it? What do I do with it if I do remove it?
robsouth
Near Atlanta, GA
Good Sam RV Club
I really don't think it will be a problem. Just forget about it and go camping.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
smkettner
Good Sam RV Club
As long as it can vent through the slots in the split ring I would leave it as is.
If you filled it to the brim with no space to vent then you need to take some out.
Jerrybo66
AZ
I swiped my wife's turkey baster for filling batteries. There's room for a light while filling so I can see what I'm doing. It also works well on ATV batteries.....
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
smjanes
Ottawa
It should be able to vent through the split ring (I'll confirm tonight) so I guess I'll leave it. The odd thing is that it was either over filled when I bought it in May, or it lost absolutely no water during the whole summer since I added very little water to it.
tomousecap
East Moline, IL
Good Sam RV Club
Remove the extra store it in a jar or plastic container and wait until the same cell needs water later. Use it up then to top off the SAME cell. That will restore the acid ratio as it should be.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2005 Saturn Vue V6 AT FWD Toad - Love it!
Scavenger Power Exh. Installed.
marvmarcy
Polson, MT, USA
Good Sam RV Club
There is plenty of room above the plates for liquid. I doubt you overfilled it enough to matter. I got a battery water container that has a spout that won't let you overfill. When the battery fluid level gets to the end of the spout it stops fillling. I have used it for many years on many different batteries. Sure makes it easier!
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK (20K GVWR, tandem duals)
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Polishnurse
Schodack, NY
smjanes wrote: It should be able to vent through the split ring (I'll confirm tonight) so I guess I'll leave it. The odd thing is that it was either over filled when I bought it in May, or it lost absolutely no water during the whole summer since I added very little water to it.
I've had the same two coaches batters for two years, I use it for five months each year, that's ten months of solid use. I used to check the batteries every few weeks, then every few months, now once a year. I don't think I have put in more then pint between all the cells in the hole time I've had them. Has me scratching my head every once in awhile, but I guess it's how much you discharge and the rate of recharge, your guess is as good as mine.
Note I had to change the chassis battery just a week ago. Go figure.
JUrban
Delaware
I haven't looked in my wet cell batteries since the coach was new. We installed one of these Pro Fill. A bit pricey, but once you use one, you'll never use anything else. Sure beats one hand for the turkey baster, one for the flashlight and one for the mirror. Camping World has them too.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
smjanes
Ottawa
JUrban wrote: I haven't looked in my wet cell batteries since the coach was new. We installed one of these Pro Fill. A bit pricey, but once you use one, you'll never use anything else. Sure beats one hand for the turkey baster, one for the flashlight and one for the mirror. Camping World has them too.
John
For $68, it would be worth it. Seeing into the rear cells is a PITA.
