4WallCamping
Northwest Illinois
...and cause damage, mildew, or mold. So after searching, I had decided this was my weekend "Mod" to perform. I had seen this similarly done on someone's mod page. However, the gap was so wide on mine that I had to get PVC Quarter Round for the base.
Here is the before, by the sink:
Here is the shower surround before:
Here is the Sink Side, after:
Here is the shower surround, after:
I still have to get a trim piece of board for the sink base. I also put a corner splash guard on the other side of the shower surround.
Just thought I'd share...
last
edited 09/20/09 08:16pm by an administrator/moderator *
View edit history
4WallCamping
Formerly: GoneRooing
DW and Son (10y/o) still at home...
2 DS, 2 DD, 2DD-in-laws, and 2 DGKids not at home...but will be camping with occasionally
2003 F150 Heritage Edition 4x4 5.4 V8
2008 Rockwood Roo 21SS
BP88
St. Louis, MO
Looks GREAT!
I have a terrible time trying to caulk neatly.
"Here we go, life's waiting to begin."
Gaffer222
Northwestern CT
Good Sam RV Club
Nice job.
You may want to remove the caulk from around the bottom of the shower surround though. That area is meant to be open for ventilation behind the surround. The base goes up the wall several inches and you should not have any issue with water getting into that area without caulking.
2004 Ford Explorer - V6 w/Tow package
Equalizer & Prodigy
2005 EZ190 Keystone Zeppelin HTT
DW, DD Circa 2002, DD Circa 2005
My Webshots
drenjoey
Poland Spring, Maine
Here's a way to do caulking that might help. Put a strip of masking tape at the top and bottom of the area you want to caulk, then put the caulking.
Put some dish soap in a small bowl, dip your finger in it and pass it over the caulking to smooth it......That way it won't stick to your finger. Let it sit a bit and remove the masking tape.
Good luck
Dre
Dre and Joey
2004 Travelstar 21SSO
Mercury Mountaineer
robsouth
Near Atlanta, GA
Good Sam RV Club
He's right about caulking around the shower base you know. Should not be there.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
4WallCamping
Northwest Illinois
Gaffer222 wrote: Nice job.
Well that shows my newbness to RVing. Commonsense told me that I wouldn't want any moisture setting there. If no water gets in there at all and you use the ventilation fan, may I ask what difference it would make?
Thanks Again and please forgive my ignorance.
Latner
Indiana
Don't feel bad GoneRooing, I did the same thing to the shower of my new Roo. I think I'll contact Forest River and see what they say about doing this.
streamcamper
New York
Your job looks real nice. I'm not sure I agree with those who recommend not caulking the surround. Your bathroom at home is well sealed, why should it be different in the RV - especially since moisture is far more damaging in the RV than at home.
Regards...
mwebber78
Maine
Mine is caulked from the factory at the pan/wall seam. The surround onto was left un-caulked, probably to allow air and expansion.
I don't see how caulking it is going to hurt the area, the base has a 1" lip and the surround sits in it.
Michael
2 DD's and my DW
6 Acre's in Southern Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD LT 4X4
Camping Pictures
kellem
Shenandoah valley,VA
As clean a job as it is i would leave it alone,should be open at the top for ventilation.
However...they are right,it wasn't necessary.
