bsprague
Milton, WA
I have a Honda EU2000 generator for backup in case of a power failure at the condo. I try to run it about once a month and keep Stabil in the gas. After a hot August it wouldn't idle with out significant surging. It ran OK under load, but the rough idle made using the automatic "Eco Throttle" a problem. It would smooth out if I choked it a little. My guess is that the extra August heat in the garage cooked off some gas in the carburetor leaving some sludge or varnish.
I found some online suggestions to use a product called Seafoam in the gas. I don't like fuel additives but I didn't like the rough idle even more.
I changed out the fuel to fresh without improvement. I added the Seafoam and let it run for about 30 minutes. No improvement. Ran it a few days later for 30 minutes. No improvement. A few more days later I tried again and it ran smoothly! Apparantly patience and soaking help.
I guess the Seafoam works!
Bill Sprague
2004 Beaver Monterey, 8.3 ISC 350 Cummins
2007 Ford Edge AWD
9 ft Quicksilver inflatable boat w/ 15 hp Suzuki
2oldman
Moses Lake
So does not leaving gas in it.
83trekker
calgary,ab,canada
Seafoam is awsome run it in everything including my old honda gen keep it full of gas all winter with seafoam in it, 5-6 month old gas, run it every month or so and no more gummed up carb. Throw a can in your vehicle every once and a while too.
bill h
coastal reconquista
Good stuff. I recently freed up some smoking that I thought was stuck rings by putting it in through the spark plug hole and letting it sit.
Anyone got a good source for it? It is up to $10 a can at my local store. With all the family vehicles and toys, I need to buy it by the case or barrel.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
golf_bears
Rapid City, SD
One of my Hondas has the same problem. Where did you purchase the Seafoam?
raygreg
Seattle,WA
Some walmarts carry the Seafoam
Jim83Itasca
La Quinta Calif
bill h wrote: Good stuff. I recently freed up some smoking that I thought was stuck rings by putting it in through the spark plug hole and letting it sit.
Bill, Give your local Walmart a checkout.....
Jim
tvman44
Southwest Louisiana
I get it at Walmart.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
bsprague
Milton, WA
I bought mine at Autozone.
bsprague
Milton, WA
2oldman wrote: So does not leaving gas in it. I can't use it for much without gas in it! So about every 6 months or so I add some gas to DW's car. She is always pleasantly surprised by the improvement in her milage records.
