enblethen
Moses Lake, WA USA
Good Sam RV Club
I would use wire nuts.
Bud
Suzuki XL7 pushing Pace Arrow
Cousin_Eddy
Peoria, AZ
Thanks to everyone for all your help!
1995 33' Southwind Fleetwood Model LW
enblethen
Moses Lake, WA USA
Good Sam RV Club
I should have said to put the splice in a box.
I am glad you found the problem and didn't have to take too much apart or take it to a dealer.
Cousin_Eddy
Peoria, AZ
What if I lap solder the leads together and cover with shrink tube? This may be more reliable than nuts. Or, are you not supposed to solder 120 VAC wires?
enblethen
Moses Lake, WA USA
Good Sam RV Club
Yes, you could twist and solder, then wrap with cushing tape and then heat shrink.
It still should be in a box to prevent a fire if there was a problem.
I would not say that solding is better then wire nuts. On 12 volt stranded wire yes, on 120 volt, solid wire no.
stacaz822
Phoenix, Arizona
If you have any more of those connectors, I would find them and replace them...don't want your RV burning up.
Stacaz
stacaz822
Phoenix, Arizona
not supposed to solder solid wire. solder is too soft, can break.
Cousin_Eddy
Peoria, AZ
That makes sense not to solder solid wires. So, a metal box, grounded, with wire nut connections. That should be pretty reliable. I have to find a very small box. There is not much room.
stacaz822
Phoenix, Arizona
I would just zip tie the two wire bundles together tightly and use big wire nuts.
enblethen
Moses Lake, WA USA
Good Sam RV Club
The box does not have to be metal. It can be bakelite. A small box is available
RV stores tht are about 3x2. Should be able to find at many hardware stores. Another option is box for Wiremold or other surface raceways.
