RV.Net Open Roads Forum: Will I want to have my generator while FTing?
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Will I want to have my generator while FTing?
Full-time RVing Related Tips
KKent
Tonawanda, NY
Posted: 09/23/09 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Honda 3000 generator. I'm looking at 28-30 ft. 5th wheel RVs. It's a little heavy to move around much and appears that there is no way to stow it in the available 5th wheel storage areas. Our plans are to stay in some places with no electrical service so I think it would be nice to have along. Does anyone have suggestions on the best way to bring it along.
rv2go
Fulltime between Knoxville, TN and the coast.
Good Sam RV Club
Posted: 09/23/09 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
IMO, You will wish you had it if you leave home without it. We use ours several times when without hook ups. Granted mine is built in and I don't have the strain of loading it.
Just a few weeks ago, I was camped by a 5th wheel. He had his 3000 watt genset mounted on the rear bumper. He showed me how he opened the rear window and could start and stop the genset from inside. Real neat....Just a thought.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
skylos
Issaquah, WA
Posted: 09/23/09 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
I think that you'll find that there is a way to stow it in the 5th wheel storage areas... most have at least one compartment with a giant door. Of course, lifting it might be a chore.
When I was FT off the grid, I used a yamaha e1000is to great effect. Wouldn't run the AC or toaster though.
If you end up getting one with a by-the-landing-gear large generator compartment, I have a Dometic 4000 I'm looking to get rid of. Super quiet. You can buy it from me at most reasonable rates in Issaquah, Washington.
FLIRGUY
Ridgecrest, Ca.
Posted: 09/23/09 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
You can have a reciever hitch put on your rig. Then add one of those platforms that fit the hitch and mount gen to it.
2007 Crossroads Zinger 270RL
2006 Dodge Ram 2500 CTD
1975 Cadillac Eldorado
20 Year USN Ret.
One Shar Pei Soon
Will never marry again!
clutch1
North Idaho
Posted: 09/23/09 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Being that you already own the Honda 3000 why not just carry it in the bed of your truck. You could chain it down and just use a long cord to use it when you are hooked up. That is a lot of weight to mount on the rear bumper of your trailer unless you can weld up something that is stout.
2007 Dodge 4x4 with, Big Horn package, pyrometer, tranny temp and fuel pressure gauges, DeeZee running boards, bed rail protectors, Rhino liner, 16K Husky hitch, Maghitech tranny pan.
03 Mountaineer 5th wheel with two slides
http://www.nwbombers.com
hotpepperkid
Chino Hills CA
Posted: 09/23/09 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Carrying it in the bed of the truck which (I have done for years) has its problems. You need to park close to the camper. As we speak Im having a rack made for the back of my 5er to mount my genny and maybe my large cooler.
hpk
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
byronlj
Loveland, CO/Lake Havasu City, AZ
Posted: 09/23/09 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
I added a receiver to my frame and adapted a "hitch-haul" carrier to lock my generator to. I then made a short 6' 50A shorepower cord from an electric range cord and plug it in right around the corner. I wasn't too worried about the extra weight in the back due to the pin weight of my trailer.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
RVJohn
Posted: 09/24/09 02:37am Link  |  Quote  |  Print  |  Notify Moderator
The generator in my sig.About the same size as yours,I carry on a front mounted receiver hitch.On a cargo carrier.Works for me.
tow vehicle-2004.5 Dodge 3500 SLT Quad Cab 4x4-600 Cummins Turbo Diesel-4-speed automatic,48RE,short bed-SRW
Prodigy brake controllar
2001 3280RL Montana
reese 16K slider,roll&lock bed cover
Yahama EF300iSEB
Garmin 7200 GPS
5th Air Borne/sidewinder
garry1p
Oklahoma
Good Sam RV Club
Posted: 09/24/09 06:32am Link  |  Quote  |  Print  |  Notify Moderator
A friend of mine went to Harbor Freight and bought a bed mounted hoist that he uses to load and unload his generator and it really works great.
When not in use it is no higher than his truck bed and takes up very little room he did use a backer plate under the bed for additional support.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
4ontheroad
Vermont & Utah (born and raised Santa Clara NY)
Posted: 09/24/09 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
front mounted receiver hitch home made cargo rack works for us, runs an impact gun too for tire changes
When Seconds count, the cops are only Minutes away!
