RV.Net Open Roads Forum: 99 V10 - vapor lock? Fuel Pump relay? (in Sedona)
 > 99 V10 - vapor lock? Fuel Pump relay? (in Sedona)
Gsmitty77
San Diego
Posted: 09/26/09 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Checking in with the F53 V10 gang. 99 2 valve, 275HP, full Banks and Transcommand with larger K&N air body/cleaner.
Symptom:
Drive rig for about an hour, all up to temperature. Stop for 10-15 minutes with engine off. Go to start and engine will turn over, but will not start. If we wait for 45-60 mins, the engine starts OK and runs well.
This seems to be on hot (for San Diego) days, with humidity (again, for San Diego). It has happened four times now over three years.
I assumed it was vapor lock. But a friend said he thought that a relay/solenoid to the fuel pump, up under the hood, sometimes does not kick in.
I'm familiar, and have replaced before, the relay to the starter. I was not aware of one for the fuel pump?
Anyone hear of this, or does anyone have experience with this and advice on trouble shooting?
Some answers to possible questions:
Good gas, not old, just under a full tank (always fill on return home)
Fuel filter replaced every two years
Generator will work during this time
Engine tuned and all working well, air filter clean and not wet
Scanguage shows no error codes
Yearly full tank with three 20 gal bottles of Techron
Appreciate any advise would be appreciated,
Smitty
UPDATE:
11/1 - Thought I would update the first posting, so it would be current, and all on the info on the first posting:
- I again yesterday, had a problem with the RV not starting,after the first time it started right up. It was only driven about two hundred feet, and was not hot, so don't think it is vapor related (if that is possible with these new systems)
- I took Scotts advise, and bought and replaced the fuel relay. I made the mistake of not trying to start the RV again, before replacing the relay, as it had sat for another two hours. The RV did start after the new relay went in.
- I just called the 1st owner, and he confirmed that the unit has had the fuel pump replaced twice. The last time about 5 years ago. He said that pump was a different version, and that it was suppose to not need to be hit again. (I'll search this some more later. And look thru his receipts to see if I can find the part number of what was put in.)
- Scan Guage does not kick out any error codes.
- I think I'm going to try to stop/start the rig multiple times over the next two days. See if I have any more problems. Hoping the relay was the problem.
We are heading out on Thursday for Prescott and Sedona, so need to get it into the shop if it is the fuel pump. I will call the 800 number on Monday, and ask a few questions.
How about it from those of you with the early V10 F53's, do you think I might need a third fuel pump? Or does the Relay seem like a good candidate. These intermittent problems are the toughest to find, so if I do see a repeat of the problem, I'll hit the fuel pump next. Appreciate any other thoughts or opinions...
Best to all,
Smitty
* This post was last edited 11/10/09 09:08am by Gsmitty77 *   View edit history
BrickBrain
Pearl River, La
Posted: 09/26/09 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I had a '94 351CID in a class B that had simular problems. I could drive for hours early in the day. When the heat of the afternoon came into play, the engine would start to miss when I needed power. Shut it off and it would not start for at least an hour. Start off the next day and it would start all over. My problem was the fuel pump not putting out enough pressure. Had it changed and all was fine.
'03 Allegro 32BA on Workhorse W20
'06 Saturn Vue
Demco Aluminator
RM 9700 Brake
lyle_47250
madison indiana usa
Posted: 09/26/09 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
With modern high pressure fuel injection with the pump in the tank you should never have vapor lock as long as the fuel is under pressure.
Lyle & Ginger and the 82 Revcon
FIRE UP
Ramona, CA. USA
Good Sam RV Club
Posted: 09/26/09 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Smitty,
How is ya, Scott here, also another San Diegan. That problem is EXACTLY what we had on our older, first year for fuel injection, class C Ford. It was an 89 E-350 Chassis with a fuel injected 460 in it. We had the problem crop up going 60 mph about 50 miles west of Mesquite NV. Long story short, it was the fuel pump relay and it was originally mounted in the engine compartment in the "WRONG" position. That is, when ever the motor compartment got wet, that relay would hold water and corrode the contacts.
So, When we found out the problem, I replaced it but re-mounted it in such a manor that it would not replay it's problem. I cannot guarantee that this is your problem and, I'm not sure that a relay is still being used in these V-10s. Good luck, and by the way, if you find out what the problem is, please let me or, any one else that's reading this know. Thanks
Scott
Scott and Karla
San Diego Fire Department RETIRED
1999 Bounder 34V w/slide, V-10 W/BANKS
toad-'04 Yellow Jeep Rubicon
2002 Stream Silver Metalic GL 1800 Goldwing
KI60ND
Gsmitty77
San Diego
Posted: 09/26/09 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the posts. They prompted my thought for the month (was getting worried that I would not have one this month!).
The last thing the gent did at the smog check, was take the gas cap off to do the leak down test. When I went to remove it and put it back on at the house, once the rig would not start. It did not seem to 'feel' right coming open. I wonder if he replaced it but did not click it?
I also was thinking back, I have not had a problem for over a 14 months or so now. And, I did get a new gas cap after the previous problem, as my cap was no longer keeping a good seal...
I may have one of the best problems, a non problems...
I will call on Monday to the local Ford Truck dealer, and ask how much does the fuel pump relay cost. If they give me a price, then I know I'll need to track it down. If they say 'What?' - I won't worry about it... If I do find one, I'll clean all of the posts and connections, and check location to be sure it is a good spot (thanks Scott for that 'lesson's learned'...).
And, if I do discover I have a problem, I'll post back.
In the meantime, if anyone else has had similar experience with other solutions, please keep them coming...
Best to all,
Smitty
* This post was edited 09/26/09 10:20pm by Gsmitty77 *
Gsmitty77
San Diego
Posted: 10/31/09 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Moved this request for more help, up into the 1st posting.
Smitty
* This post was edited 11/01/09 10:08am by Gsmitty77 *
LVJ58
Las Vegas, Nevada
Good Sam RV Club
Posted: 11/01/09 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Smitty, try giving Ford's customer assistance folks at 1-800 444-3311 perhaps they can help.
Have your VIN information and current mileage available as they usually ask for it.
Best of luck and let us know the fix when you find it,
Jim
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
Gsmitty77
San Diego
Posted: 11/01/09 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Wanted to goose this up to the top, as I did update that the 1st owner confirmed he had replaced the fuel pump a few times...
1st posting has been updated with all that I think I know now...
Thk's
Smitty
Gsmitty77
San Diego
Posted: 11/01/09 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just parked the rig for the night. Over the course of the day, started the coach a total of 11 times.
Relay? I'm hoping that was it...
Will start it multiple times, the next few days, and see if I have any repeats.
It never has stopped running while on the road and moving, it has always been a 'won't start' situation.
All of my surfing searches, seem to talk about the 460 F53 fuel pump problems, with only a few talking about the V10 fuel pumps.
Please set me straight if any of you think of something else I should check...
Best,
Smitty
topflite51
In The Desert of Nevada
Good Sam RV Club
Posted: 11/01/09 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a V10, but I found it surprising when you wrote that the previous owner said he had replaced it twice all ready.
David
Just rolling along enjoying life
w/F53 Southwind towing 87 Samurai looking to golf or fish
Simply Despicable
