RV.Net Open Roads Forum: General RVing Issues: Water Pump ?
 > Water Pump ?
General RVing Issues Related Tips
popere
Denver
Posted: 09/26/09 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
I went to winterize my HTT today and when I turned my water pump on it just kept running and not as loud as normal. I made sure that all of my valves were closed went and turned it on again and it still kept running continuosly. So, I figure that the pump is bad so off to CW I went. I bought a new pump get back install it and it is still doing the same exact thing as the old one. Does anyone have any clue what the problem could be? Any help will be greatly appreciated.
Thanks in Advance
Randy
Queens Carriage
tx
Posted: 09/26/09 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
not sure what pump you bought. Some come with the pressure switch some don't did you buy the same maddel pump? Check if you have water in your tank
popere
Denver
Posted: 09/26/09 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
I did buy the same pump. I am winterizing so I don't want water in the tank. It won't even suck the antifreez out of the jug. I think I am going to put water in it tomorrow and see if I have a leak somewhere. I just used it last weekend and erverything was fine.
Bill1374
Saratoga Springs, NY
Good Sam RV Club
Posted: 09/26/09 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Lines probably were airbound. assuming you were trying to draw antifreeze from a jug, you may need to crack a faucet open to get the pump to pick up.
Bill
2006 Heartland Big Horn 3400rl
2007 Dodge quadcab, 6.7 auto
Homer
Northwest Ohio
Posted: 09/26/09 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Did you make sure that you don't have your fill valve switched to tank fill. If you do, it will just keep recirculating the water and never shut off.
Dick_B
Palos Heights, IL USA
Good Sam RV Club
Posted: 09/26/09 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes I have to have some water in the tank to get the pump to prime then it will suck out the antifreeze; then drain the FW Tank, of course.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
popere
Denver
Posted: 09/26/09 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of the replies guys. I'm not sure what's going on I have never had this problem before. I think that I have some sort of leak somewhere and will try and find it by adding water the the FW tank tomorrow.
Thanks Again
garry1p
Oklahoma
Good Sam RV Club
Posted: 09/26/09 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are getting air into the pump or a leak down stream from the pump.
The pump turns off when it builds "up" enough pressure what keeps the pump running is low pressure on the output side, air in the input line or an open faucet (lowers the pressure).
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
 > Water Pump ?
