RV.Net Open Roads Forum: Viewing printed area is larger than my monitor
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Viewing printed area is larger than my monitor
Forum Technical Support Related Tips
Admiral
Upstate Ohio
Posted: 09/28/09 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know what's going on lately but I have to scroll left and right to read the posts since the printed area runs off the monitor. Is this something on the rv.net site or my computer settings?
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Practice safe dining....use condiments.
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 09/29/09 12:05am Link  |  Quote  |  Print  |  Notify Moderator
Nothing has changed to my knowledge
junmy3
Warner Robins GA
Posted: 09/29/09 02:24am Link  |  Quote  |  Print  |  Notify Moderator
I have that problem once in a while. I will select a topic from the new topics and it will be too wide for my screen and I will have to scroll over. It seems that the page is missing the advertisement on the side. Today I have not had the problem. Who knows?
Jim & Junnie
2005 Sunline Solaris T-2553
tvme
Medina, Ohio
Posted: 09/29/09 04:26am Link  |  Quote  |  Print  |  Notify Moderator
I have that problem when someone posts a picture and doesn't bother to reduce the size to something manageable. If that is the case, you can turn off the pictures (a pain) or block the poster- also a pain because you have to be logged in for those preferences to take effect. Some moderators do go in and correct the picture problem.
If it is happening all the time... I don't know. It could be the ads if you're on the Good Sams portal. Until I started blocking them that portal was doing really wierd things. If your security settings are higher than most folks, this could be the problem.
Bob
Little Kopit
TheMaritimes.ca
Posted: 09/29/09 04:28am Link  |  Quote  |  Print  |  Notify Moderator
It could be photos posted on the page are too wide for the site or it could be your monitor settings. You want to go back to the desktop, right clik, then properties and study that menu.
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
NORM WADDELL
PENSACOLA FL 32514
Posted: 09/29/09 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Try this
Hold down the CNT button
Move the scroll wheel or whatever you have
The print may enlarge or reduce depending
on which way you scroll
L NORMAN WADDELL
30 FOOT ALLEGRO
SATURN TOAD
WIFE AND 2 DOGS SUGAR BEAR & COCO BEAR
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 09/29/09 06:50am Link  |  Quote  |  Print  |  Notify Moderator
If it is an ocasional page, then, as Little Kopit suggested, it is probably a "too wide" picture.
If it is every page, then it probably a setting in your preferences or, more likely, a setting on your computer.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Admiral
Upstate Ohio
Posted: 09/29/09 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks, the grandkids must have been playing with the computer. I realized the type overflowed in my email also.
I went to display settings and increased the screen resolution one notch. Then came back here and went to the 3 AAA on the bottom of this screen and chose the biggest one. Now all is cool. Thanks again
05 Honda Element LX
