Bearly
Naperville
Good Sam RV Club
We just subscribed to Direct TV at the stick house so we could take one of the receivers and a portable dish for TV reception while we travel. My question is this: We will be having someone stay at the stick house while we are on the road. Will we both be able to get satellite service? Thanks
Bumpyroad
Virginia
yes, don't ask, don't tell.
bumpy
Musicman
Wenatchee, WA
I would say that receiving at two locations would be doubtful. You might be able to pay an additional fee to enable what you want. You would have to contact Direct TV.
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
robsouth
Near Atlanta, GA
Good Sam RV Club
Of course you can. Thousands of folk do it everyday. The satellite does not care where you are or how many registered receivers you have or where they are. You will notice no difference at home, except that the TV that had the receiver you took with you will not have satellite reception.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
chockwald
Ontario, CA
Good Sam RV Club
Yes, you definitely can get it at both locations. I've had DirecTV for 6 years and always take one of the receivers on the road when we travel. Have watched DirecTV as far away as Northern Washington, Austin, TX, eastern Oklahoma, while my son at home watches. Each receiver is completely independent from another.
CLARKE AND ELAINE
1982 Newell 36' diesel pusher
skipnchar
Topeka Kansas USA
No problems as long as you don't try to have LOCAL channels at both locations. The EASY way to get locals while traveling is with the antennae anyway. If you connect your DTV receiver through your video ports instead of hooking up to the antennae wire, you can use your remote to change the input from air to video to switch back and forth from local channels in the area you're located, to DTV programing.
Good luck / Skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
djgarcia
Northern, Ca. , USA
Bearly wrote: We just subscribed to Direct TV at the stick house so we could take one of the receivers and a portable dish for TV reception while we travel. My question is this: We will be having someone stay at the stick house while we are on the road. Will we both be able to get satellite service? Thanks
With Dish you just pay an additional $5 per month and you get another receiver for your RV. Then you don't have to go through the hassle of disconnecting and connecting etc etc. everytime you hit the RV road.
Dick
djgarcia@earthlink.net
elh0146
Sioux Falls, SD
As long as the TV in your sticks & bricks has it's own receiver and the TV in your RV has IT'S own receiver, then the answer to your question is "yes." The only difference between the programming with be that YOU will lose your locals once you leave the spot beam area, but all other programming will be the same.
mikestock
Vestavia Hills, AL, USA
DirecTV has no idea where your receivers are located unless you connect a phone line from your home location. The receiver sends no information to the satellite.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Honda EU2000i, Porta Bote with 6HP Nissan and sail kit, S&W security system
dadd45
northeast NEBR USA
Just be sure to take the CORRECT remote control along in the RV so as to control the matching receiver.......
DadD45
2004 Cross Country Coachmen
2001 Wrangler behind
JUST HAVIN' FUN!!!
