RVUSA
Orlando, FL, USA
The tv should be able to accept the digital converters output. I would put that back in and see if it doesnt work just as well as before.
ronfisherman
SE Michigan
jcrawford wrote: My sony lcd has "signal diagnostics" located under "channel & inputs"
When in s. diagnostics & it gives you a signal meter...I use it to fine tune over the air channels. Unlike analog...you either have enough signal or you don't...upside no snowy pictures...down side...not as many channels.
ronfisherman is right...consider a first tier tv..they are better made, have better features, & are repairable. 3rd tier tv's are throw aways...& built as such. Not sure about Viewsonic being a tier 1, however I do know they make good monitors. He is dead on the name brands you should stick with.
If me...I would only shop Sony & Samsung.
I put Viewsonic on my list because I have one. For a 22" TV it is a high quality unit.
Kodiak Chassis Class C Forum
Turbo Diesel Dude
Green Mountain, NC
I replaced our 19" old style (2006) with a new VISIO 22" digital and couldn't be happier. Lots more channels with the antenna than the old. JMHO
charles weidman
pkunk
Questa, NM
Hershey, go back to using the converter. It has a better tuner.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH 3 stage WFCO 55A converter upgrade
SCVJeff
Santa Clarita, CA.
mainetom wrote: othertonka wrote: ....Point the flat side of your Winegard antenna, the side oposite where the coax enters the antenna head, toward that direction and then do another scan...
Well there, not even through my first morning cup of coffee and I already learned something. I've always wondered which way to aim those darned things. Now I know. Thank you othertonka, and thank you rv.net
Jeff - WA6EQU
ronfisherman
SE Michigan
Next time you are in a RV park. Look around and see which direction all the antennas are pointed.
hwybnb
ronfisherman wrote:
Next time you are in a RV park. Look around and see which direction all the antennas are pointed. You are joking, right? Looking around here in the RV park at the Albuquerque Balloon Fiesta it is obvious that most people do not have a clue. The transmitter towers are clearly visible on the mountain but antennas are pointed every which way.
edited 10/04/09 05:00pm by hwybnb *
hershey
Albuquerque,(fulltime) NM, USA
Well, I figured it out. I put my digital converter back in line and I have all 22 stations back. Thank goodness I depend on satellite for the vast majority of TV viewing, but do like to tune into local stations for weather and news, etc.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99 - 5
Wherever I happen to park
Well as others have said, Some tuners are better than others. There are a few other things that can affect it too.
But there is GOOD NEWS
you can,, if you wish, Keep using the converter that works so well.
Thor20003
Northern Oklahoma
Turbo Diesel Dude wrote: I replaced our 19" old style (2006) with a new VISIO 22" digital and couldn't be happier. Lots more channels with the antenna than the old. JMHO
My Visio 22" could not fine any stations this weekend at a park when others were picking up channels.
I'm going to try to find one of those converter boxes.
