johncrazyels
Vancouver/California
Good Sam RV Club
Can anybody tell me what the normal running temperature is - measured at the hub cap - for Nev-R-Lube bearings? Also, what temperature would indicate a problem with the bearings. I want to buy an infra-red thermometer and want to be sure I have an adequate temperature measuring range on the thermometer.
tvman44
Southwest Louisiana
Main thing is all four are about the same. Mine run about 100 to 125 depending on conditions, but like I said they should all be about the same.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
sstgermain
Oceanside RV Park, Magnolia Beach,Tx
Mine run about the same... Ive seen em as low as 115 and as high as 123.
I think that is pretty much the norm. Anything over 135 to 140 I'de start getting concerned
Steve & Joy . . . 2009 Montana Mountaineer 347 THT . .
2006 GMC 2500 HD 6.0 Long Bed . . .
Yogi, Teddy, Ranger Smith. . The Yorkies.
Cookie the Chiauaua.
Polishnurse
Schodack, NY
As mentioned above, all should be in the same range. thermal thermometers are fairly cheap under $50.00 and are fun to use at an all night party. What ever you do, make sure it's fun. Bill
skeetshooter
The Woodlands, Texas
Why don't you call Dexter and ask them? That way you get the correct information.
SS
Skeetshooter and Mrs. Skeetshooter
2004 HitchHiker Premeir 33LKTG
2003 F250 Lariat 6.0L SD diesel CC, Longbed,4X2 SRW
20K Reese Hitch, Tekonsha Voyger BC, Quadra Auto Big Foot Levelers
johncrazyels
Good Sam RV Club
The answer from Dexter was that there are too many variables to give a specific answer. However, "if you get a blister on your finger when you touch the hub it is too hot".
Dave H M
IL
keep in mind that the hub may pick up some heat if you did a lot of braking before checking the heat.
Skip N Barb Team
Dickinson, Texas
I've worked with all types of bearings for over thirty years. A greased roller or ball bearing should be fine up to around 160 degrees, although the cooler, the longer life you can expect.
You can get a blister on your finger by touching something at 130 degrees or higher. 130 degrees won't damage the bearings.
tvmann44 hit the nail on the head. If one bearing temp is showing 15 to 20 degrees higher than the rest, there's something going on.
And yes, a lazor temp gun is a very good tool to keep an eye on these.
Good luck and happy camping.
robertbick
Upstate NY
I only remembered to check mine once. It was at a rest stop on the NY Thruway and all four hubs were withing 5 degrees of each other. If I remember correctly, they were about 110 degrees.
Bob
2008 Chevy Silverado 2500HD 4X4 LTZ
2010 Keystone Cougar 276RLS Pictures
PullRite Superglide 14K Hitch
Duck
Miami Lakes, Fl
Good Sam RV Club
I found that on my trailer is that if one side of the trailer has been running in the sun the wheels on that side are warmer then the wheels that were running in the shade side.
Don
08-FORD F350 PSD
08-Hitchhiker II 34.5 UKSBG
