RV.Net Open Roads Forum: Steer safe install and test drive, results
 > Steer safe install and test drive, results
FIRE UP
Ramona, CA. USA
Good Sam RV Club
Posted: 10/06/09 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Well gang,
I did a little test drive with Steer safe installed. Based on the fact that we have two straight roads in our area to test on, it seems to be working fine. The roads have some crown in them so, an accurate test is not complete. Most of my wandering problem is on longer straight runs like from San Diego to Las Vegas and many others we encountered on our recent trip in the western U.S.
Some of you were interested in my results of the test drive because you experience some or many of the same wandering characteristics. If you've read my other post(s)on this subject, you'll know I've done all the preliminary steps before adding aftermarket gadgets. So, in the interim, for anyone who cares, when I take the beast out for a longer ride and hit some straights that I know she'd be wandering on, I'll report on the "then" conditions and results. Thanks
Scott
Scott and Karla
San Diego Fire Department RETIRED
1999 Bounder 34V w/slide, V-10 W/BANKS
toad-'04 Yellow Jeep Rubicon
2002 Stream Silver Metalic GL 1800 Goldwing
KI60ND
Polishnurse
Schodack, NY
Posted: 10/06/09 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update, but be sure to post the highway results, I'm interested in the wind gust truck passing. Thanks Bill
Gale Hawkins
Murray, KY
Posted: 10/06/09 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Our PO said it was the best $350 he spent on the 1992 P30 chassis the 10 years he owned it. Ours drives like a dream without truck and wind causing driving issues. Now you will know about 40 MPH cross winds but you sit feel a good degree of control.
don/lou
Brandon MB Canada
Good Sam RV Club
Posted: 10/06/09 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thx Scott
I will be awaiting future update as well
Hope it works!
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
ernestfortier
Palmdale, Calif.
Good Sam RV Club
Posted: 10/06/09 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like we have the same unit. I have the Steer safe on mine already and it still wandered. I took the unit to a good Alignment shopand paid $75.00 to get a alignment. No more wandering, it was mostly the alignment. Good luck.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
GrumpyandGrandma
CIncinnati, OH
Good Sam RV Club
Posted: 10/06/09 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used one on an E450 Jayco 32' and it worked wonders.
Grandma in front of her retirement home..
She lets Grumpy drive!!
FIRE UP
Ramona, CA. USA
Good Sam RV Club
Posted: 10/06/09 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
ernestfortier,
I sent you a PM about your rig.
Scott
kiloo9
Houston Texas
Posted: 10/06/09 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
How hard was it to install the "Steer safe kid?" Did you do it yourself?
I have a 2004 Holiday rambler 30' workhorse chassi.
Polishnurse
Schodack, NY
Posted: 10/06/09 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
It's not hard if you don't mind laying on your back and working. The kid or kit comes for the Vehicle. Following directions, and a few wrenches. A few hours at best. Bill
Here is another thread showing the install. Steer Safe install
427435
Rochester, Mn
Posted: 10/06/09 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
What is your caster angle????
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
