RV.Net Open Roads Forum: Streets & Trips 2010 does not send route to GPS
 > Streets & Trips 2010 does not send route to GPS
Technology Corner Related Tips
rhingst
Livingston, Texas USA
Good Sam RV Club
Posted: 10/07/09 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I downloaded the trial version and then thought I was sending a route to my Garmin 465T but it only sent the waypoints/favorites. I was sending via the USB cable and yes, I did select the second option of sending the route. So, looks like I will continue to use GPSBabel since it works correctly and sends the route. So just another instance of MS saying they have something when they don't.
2008 Ford F350 Lariat Crew Cab Powerstroke SRW
2007 Hitchhiker Discover America 339RSB
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 10/07/09 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the trial version is not fully functional.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
sch911
Rochester Hills, MI
Posted: 10/07/09 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
The 465t is not on the list of supported devices so far as I can see.....
Test & System Engineer (Thermal Systems incl. towing, Detroit 3)
2003 Damon Challenger 348 Class A - F53 Triton V10
Posted by Macintosh
rhingst
Good Sam RV Club
Posted: 10/07/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
The trial version is fully functional. When you buy S&T you just enter the Key Code when you start the trial version and it will register it and remove the 60 day limit.
Also, it should send routes to any Garmin that handles routes. The 465T can store 15 routes.
You can, however, export as a GPX file so that is a way to get your route to your Garmin.
SidKaye
Posted: 10/07/09 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Well I just went through downloading the Garmin plugin only to discover that my Etrex Vista CX is NOT supported. Oh well there is more than one way to get routes into my Garmin as well as my Tomtom.
Sidney
garym114
Posted: 10/07/09 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
The 465t is not on the list of supported devices for MSN Direct transfers. See the supported devices list.
Export the route as a GPX file.
* This post was edited 10/07/09 10:49pm by garym114 *
Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
rhingst
Good Sam RV Club
Posted: 10/08/09 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Gary, You are correct, I discovered that last night and it works perfectly. Just hook up the Garmin with the USB cable and export the route directly to the Garmin.
