RV.Net Open Roads Forum: Tech Issues: Bathroom fan timer
 > Bathroom fan timer
Tech Issues Related Tips
chunme
FT West Coast
Posted: 10/10/09 10:55am Link  |  Quote  |  Print  |  Notify Moderator
The bathroom fan in my Ragen was controlled by a switch mounted on the screen. It worked fine except you had to go back and turn it off, which means it could run for hours and suck up fumes from the tank. Not a big problem, but the fix was easy.
I installed a timer switch, about $12, they are made for 110VAC, but that doesn't matter as the timer is spring loaded. In my case there was no convenient space behind the wall or in the ceiling, so I just made a small wooden box for surface mounting.
Now I just turn it on for a few minutes and forget it.
Peter
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 10/10/09 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
ghamblen
Wilder, ID
Posted: 10/10/09 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Why not just turn it off when you leave the bathroom? I must be missing something important here.
Gary & Mary Hamblen
2006 Gulfstream Ultra LE 6316
2006 Saturn VUE
Roadmaster Sterling tow bar with US Gear Unified tow brake
cctv
Minneapolis Minnesota
Posted: 10/10/09 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Think about it....
john b
anywhere USA!
Posted: 10/10/09 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
You must be one of the blessed ones whose Excrement & Gas are odorless! Good for you!!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
javaseuf
California's Gold Coast
Posted: 10/10/09 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
2007 Springdale 291RKL
2009 F150, 5.4 ltr.
1986 Palomino Hard-Side PUP
"Nobody knows how we got to the top of the hill, but since we're on our way down, we might as well enjoy the ride". ("The Secret Of Life", James Taylor).
bill h
coastal reconquista
Posted: 10/11/09 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I never turn ours on until after the toilet is flushed. That way, no odor is sucked from the tank into the interior. Our fan is two stage, high for odor clearance, and low for fog clearance while showering.
And a timer, of course.
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
redwake
Visalia, CA
Good Sam RV Club
Posted: 10/13/09 10:15am Link  |  Quote  |  Print  |  Notify Moderator
you going to post some pictures of the mod? more details about the timer incase some one like me is interested in doing it?
TT: 08 Monterey 27 PT by Extreme RV
TV: 06 Sierra K1500 SLE Crew - 3.73:1 4x4 w/5.3L
Hitched with a Husky WD & SC.
Powered by Champion 3500
Fizz
Ottawa, Canada
Posted: 10/13/09 10:21am Link  |  Quote  |  Print  |  Notify Moderator
While we're on the subject.
I replaced our noisy fan with a 12v fan from an old PC. It's not as powerful but we can't hear it so we tend to use it more and leave it on longer.
MattR
Great Falls, MT
Posted: 10/13/09 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
You should probably leave your fan on for at least 20 minutes after taking a shower. I leave mine on longer to make sure I don't have any issues with moisture buildup in my RV.
I've been eying the 120v fan timers at Home Depot. The last time I was there, they were all on clearance but the one I wanted was still more than I was willing to spend (only for the white one - the other colors were all cheaper).
