RV.Net Open Roads Forum: Technology Corner: Quick MSCONFIG question
 > Quick MSCONFIG question
Technology Corner Related Tips
mr. ed
So AZ in winter, higher elevations in summer
Posted: 10/10/09 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, friends. I'm running Windows XP, Service Pack 3 on my Toshiba laptop. Some time ago I was "experimenting" with changing MSCONFIG from Selective Startup to Normal mode when I caused the computer to hang up and a blue screen with some kind of warning to appear. I had to shut the computer off manually when this happened. I put MSCONFIG back to Selective Startup and all seems to be working normally, although I'll get a message that says, in effect, "MSCONFIG is not in Normal mode" when I restart the computer from a complete shut-down.
My question is: can I just leave MSCONFIG in the Selective Startup mode or is it advisable to use Normal startup? I've deselected several start-up items in the start menu and if I go back to Normal mode I believe all items are automatically checked. Hope I didn't make this question too complicated....Thanks. (I'll be online again Tue. to retrieve your answers and advice). Oh, BTW I've done Google searches on MSCONFIG and am still a little unclear.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
ralphnjoann
Canon City, CO
Posted: 10/10/09 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
You can leave it in Selective Start up if you don't want the items you turned off to load. When you reboot, check the box so you don't get the MSConfig message each time you boot up. MSConfig is overkill IMHO if all you want to do is enable/disable startup items. CCcleaner has a much easier interface in their "Tools" option.
mr. ed
Posted: 10/10/09 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick reply. I was just about ready to shut down my computer when I received your message....
4aSong
Northwest Arizona
Posted: 10/10/09 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
ralphnjoann wrote:
MSConfig is overkill IMHO if all you want to do is enable/disable startup items. ccleaner has a much easier interface in their "Tools" option.
Totally agree, ccleaner has a much easier interface.
Mike and Nancy
Tundra TRD V8 4WD
Prowler 20' Lite ( The Kramalot Inn )
EU2000i * Prodigy * McKesh * Trek
MrWizard
Van Nuys, Ca
Posted: 10/11/09 12:20am Link  |  Quote  |  Print  |  Notify Moderator
I have one called 'start up control panel' and there is another called 'start up cop'
very handy for disabling or enabling,
especially things that like to sit in the systems tray
Connected via Verizon Via Motorola Droid with Android2 OS
lwmuddy
Wallingford,PA
Posted: 10/11/09 05:13am Link  |  Quote  |  Print  |  Notify Moderator
CCLEANER Ditto.
mr. ed
Posted: 10/12/09 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using CCleaner for a number of years but never thought to use it in the way you folks mentioned....thanks.
lynndiwagon
Yukon, Oklahoma, USA
Posted: 10/12/09 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Try "Advance System Care - Free". It's a great program and has a utility for managing startup.
Lynn & Diana Wagoner
One Shih Tszu
Two Boston Terriers
2005 Chevy 2500HD D/A
2006 HHII 29.5LKTG
Retired Gov't employee
faulkner1953
McKinney, Tx
Good Sam RV Club
Posted: 10/12/09 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
My computers are always in selective startup. Never bothered them at all. I don't even think about it. I want to keep those programs from running at startup. MSConfig is the easiest way to accomplish that.
Regards,
Gary
2008 Ford F250 XLT Crew Cab short bed V10 gas
Pullrite Superglide hitch
2008 Laredo 265RL
mr. ed
Posted: 10/13/09 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
This is the way I've been running mine until I started experimenting. I'm still a little confused, though. Isn't Normal Mode the correct way to run the computer if you're not troubleshooting? If not, why is it called "Normal Mode"? I'm happy to keep using Selective Mode but if there is some benefit in using Normal Mode I'd like to know about it.
Also, some of you folks have mentioned using CCleaner to remove start-up programs instead of MSCONFIG. Is that to say that I can disable the programs using CCleaner and then return MSCONFIG to Normal Mode? Will the programs disabled by CCleaner disappear from MSCONFIG?
The reason I ask beforehand is that I don't want to cause any serious problems (like failure to boot or the dreaded BSOD) from which I can't easily recover. Again, I thank all of you for your assistance. It's really appreciated...Ed
