RV.Net Open Roads Forum: Around the Campfire: Pressure washer basics ? ...
 > Pressure washer basics ? ...
Around the Campfire Related Tips
MasterBoondocker
nw lower Meeeechigan, TN and FL
Posted: 10/10/09 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
For a friend .. and I might use-it from time to time.
Gas or electric? .. is there THAT much of a diff in the successful operation between a 1400 psi ... to a 2200 psi? ...Is all that extra PSI really needed?
Any other info would be appreciated.
Orion
Pacific South West
Posted: 10/11/09 12:26am Link  |  Quote  |  Print  |  Notify Moderator
There are a few things that a gas one can do that an electric cannot, but generally the 2200 psi can damage quite a bit of stuff.
Of course the same lot that think you need a one ton dually to pull a pop up will disagree with that! MORE POWER & the BIGGER THE BETTER!
Never miss an opportunity to walk on the grass.
Kajtek1
CA
Posted: 10/11/09 12:43am Link  |  Quote  |  Print  |  Notify Moderator
I own 11 HP 3000 psi industrial washer and sometimes I wish I had more power
You need high pressure for deck and concrete cleaning. For engine, or gutter cleaning the 2 HP electric will do.
Pressure washers are lousy car cleaning tools. You still need to brush it to remove sticky dust.
topflite51
In The Desert of Nevada
Good Sam RV Club
Posted: 10/11/09 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have an electric 1700 psi cleaner. It does decks and concrete just fine, it just takes more time. The higher the pressure the more care and caution needs to be exercised.
David
Just rolling along enjoying life
w/F53 Southwind towing 87 Samurai looking to golf or fish
Simply Despicable
belfert
Shoreview, MN, USA
Posted: 10/11/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a medium size pressure washer. With the right tip it will actually etch concrete. I'm not convinced bigger is better.
With a 10 or 15 degree tip I can't really clean concrete all that well, but a zero degree tip will remove the concrete. I doubt more PSI would help as the concrete would just get eaten away faster.
I got a really good pressure washer cheap at Home Depot some years. They had a 40% off sale on all clearance items.
Kajtek1
CA
Posted: 10/11/09 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hey. I can clean the concrete with my Waterpik (tooth cleaning tool) or even my 3000 psi paint pump.
But cleaning 60 feet of driveway while making 1/16" pass is going to take looong time.
HD and other places have very good rotating tips for cleaning, but I think it requires 6 HP minimum. With my 11 HP washer it makes about 8" wide cleaning path on concrete or about 12" on wood.
Veronica
Virginia
Posted: 10/11/09 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
I'm perfectly happy with my little electric one. And so is everyone who has borrowed it this summer. I've only had it in my posession for two days since May - it's been passed from friend to friend since then.
Will it knock paint off my house from two stories down? Probably not. But for cleaning the deck and the sidewalk, it's perfect.
'98 Suburban
'73 Apache Roamer (hard sided popup) traded for
'73 Nomad
"You have to write the book that wants to be written. And if the book will be too difficult for grown-ups, then you write it for children."
~~Madeleine L’Engle
4*phun*2
Canada
Posted: 10/12/09 08:26am Link  |  Quote  |  Print  |  Notify Moderator
IMHO the quality of pressure washers is VERY poor. My electric Simonize continuously breaks a plastic elbow in the handle. The first time it broke it was about a month out of warranty.
My gas takes about a long time to built pressure. Again work OK when brand new.
I think all those that will inject soap, will only do this at low pressure settings which is useless.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
Kajtek1
CA
Posted: 10/12/09 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I have telescopic vand for mine, that also with pointed tip will blast a hole under the driveway for new pipes installation.
trafficmaker
SC
Posted: 10/12/09 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Mine will peel the skin off your foot, so my tip is to wear shoes if doing driveways!
I used/use mine to make money on the side doing jobs, so it is gas operated. I also use it on tractors, bush hogs and disc harrows to keep cross contamination (weeds) of fields at the farm.
2005 F250 SD FX4 Crew Cab 6.0l PSD
2005 Gulfstream Sedona 31 FRBH
