RV.Net Open Roads Forum: Tech Issues: Pocket Door Repair
 > Pocket Door Repair
Jusnew
Mead, Washington
Posted: 10/11/09 04:51pm Link  |  Print  |  Notify Moderator
How do I get my pocket door off to replace the back device that slides on the track?
It almost looks like I have to take part of a wall off to remove the door.
Any ideas or experience with this problem would be appreciated.
Thanks, Mike
2005 Everest 344J
1 wife
1 cat who thinks she owns it all
hilcodil
Dillon, Co
Posted: 10/11/09 04:57pm Link  |  Print  |  Notify Moderator
Look on top of the door where the hanging support is. There should be some type of cam lock devise built into the hanger. It will probably be very hard to push, but it will go and this will drop the door off of the hanger. Then you can pull the door sideways and out of the pocket to release the other one. Good luck.
Tom Hill 2003 Safari Cheetah DP
chipper
Nampa,Id
Posted: 10/11/09 05:02pm Link  |  Print  |  Notify Moderator
You will probably have to remove a cover piece of plywood to get to the hangers above. It is about 2-3" wide to hide the track & is held by a few small screws.
gene
chassis
Penn's Woods
Posted: 10/11/09 08:13pm Link  |  Print  |  Notify Moderator
Like hilodil said, there is a plastic cam lock. I use a slender flat blade screwdriver to lock and unlock them. One of my pocket doors guides likes to come undone during travel, so I have gotten pretty handy, not by choice, at this task.
2003 F-250 6.0 Powerstroke diesel, 4x2, crew cab short bed
2004 Cardinal T31BH travel trailer
larry barnhart
wenatchee. wa usa
Posted: 10/12/09 10:30am Link  |  Print  |  Notify Moderator
sometimes lifting up on the door slighty will make it easier to unhook and rehook what the above are telling you. Might not be so important because your door could be lite weight but just a thought if you have trouble.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
