RV.Net Open Roads Forum: Tech Issues: New 6 volt batteries installed - question
 > New 6 volt batteries installed - question
Tech Issues Related Tips
stevenkd
Simsbury, CT
Posted: 10/11/09 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced our 5 year old deep cycle battery with 2 new 6 volt energizer GC2 batteries from Sams club. I made sure they were fully charged before leaving. They seem to be working well, however they do not stay on full charge status for more than a few hours, but stay on 3/4 all night even with the heater running. I am charging with the generator each day. Is this normal or should the full charge status stay on longer?
stevesandidge
kingsport tn
Posted: 10/11/09 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
do you have a volt meter? is the converter charger working? check the fuses on the converter? what brand of converter do you have installed now?
steve
steve sandidge
RVIA certified rv tech
camping world rv university
class 54
fix-it rv service
USMC 1982-1994
91 holiday rambler imperial 37'
hwybnb
Posted: 10/11/09 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I gather that you are depending on the simple LED indicator panel to give you status. Those are pretty crude and what you are seeing is probably normal. A digital voltmeter would give you more accurate information. For a truly accurate state-of-charge readout you need a digital monitor like the Xantrex Link 10 or Trimetic.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 10/11/09 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
12.7 at rest is a fully charged battery. Once you turn on any of the 12 volt lights or appliances, it should start to drop in relation to the amount of draw you have. Lights, little draw - furnace, big draw. TV intermediate draw. Once its down to about 12.2 you should consider recharging. Once fully charged, you might end up with 13 to 13.5 volts for a brief period of time and settle in at 12.7 again.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99 - 5
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 10/11/09 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
An in expensive cigarette lighter digital meter will give you a better indication of your battery status. Prime products model 12-2020 or similar available at many stores including O'rielly auto parts and Walmart for around $15
http://www.primeproducts.com/products.php?prodid=100
Bud
Suzuki XL7 pushing Pace Arrow
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 10/11/09 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
The 12volt Side of Life
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
teb1272
Memphis
Posted: 10/11/09 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
It is normal to go from 50-60% charged to about 80% when running the generator for an hour or two if you have a good converter/charger. If you have a really good converter/charger you might do slightly better, and you might get better by running the generator and running a good battery charger along with your converter/charger. Most converters, however, are not really all that good at charging the batteries and some are really lousy at it-it may take many hours of generator running to get a high level of charge.
Golden_HVAC
Fulltime, CA, USA
Posted: 10/11/09 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I would expect the "Full" 3/4 and 1/2 lights to not be very accurate, and the full light probably shuts off at 12.6 volts, while the 3/4 might shut off at 12.2 or 12.1 volts.
I think you will be happy with the new battery set-up.
Don't worry to much that the full light does not stay on a long time. Only when the 1/3 full light is not coming on, that means you really need to recharge.
Good Luck!
Fred.
smkettner
Good Sam RV Club
Posted: 10/11/09 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what full means. My "full" does not last long but then "good" and "fair" goes a long long time.
liborko
Surrey, B.C.
Posted: 10/12/09 01:29am Link  |  Quote  |  Print  |  Notify Moderator
1.) new batteries may take up to 15 charge/discharge cycles before they develop full capacity.
2.) when charging with a generator it takes forever to reach 100% charge. It is not practical or wise to do that. Most people charge to about 80% and finish with solar or wait till they get home or shore power.
