RV.Net Open Roads Forum: retractable awning not closing all the way
 > retractable awning not closing all the way
john-damondaybreak
maryland
Posted: 10/11/09 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'm having a problem with my retractable awning (manual spring loaded type). It's getting stuck in the arms along the RV when trying to close it. The awning doesn't want to seat all the way into the arms.
I think the problem is that the pin holding the awning has slipped a little bit out - making it not line up exactly with the arms.
Question - can I loosen the set screw a little to push the pin further into the arm? Or am I looking at disaster because the awning is under a lot of tension and loosening this set screw will cause havoc?
I've included 2 pics, but I don't know if I'm doing it correctly. Hopefully you can see what I'm talking about. It's kind of hard to explain withoug a pic or two.
Thanks.
Diplomat Don
Moorpark, Ca
Good Sam RV Club
Posted: 10/11/09 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
John.....I'm not sure what you're describing, but often the awning shifts a little to one side or the other and then binds up when rolling it up. If it's off to one side, open it and then have someone at the rear of the awning push it forward (toward front of coach) or back (toward rear of coach) to get it to seat/retract straight.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
Desertcat921
HERMISTON OR
Good Sam RV Club
Posted: 10/11/09 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the awning can slip on the main roller tube and will slide back into postion with a little help. the awning track has a keeper screw in it and so doesn't slip. like the roller tube
1988 MCI Widebody 40' Coach Conversion, 8V92TA Silver w/ Allison 740
Auto Transmission. 480 Watts Solar, Hughes Satellite Internet W/ Motosat Datastorm, Dish TV. One Cat named Monkey..
bubbabod
Beautiful Carlsbad, California
Good Sam RV Club
Posted: 10/11/09 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with my awning in March while staying at Folsom Lake SP. The campground host named Jerry came over to show me how to correct it. Like the first two posters said, in my case the wind caused it to be a little out of alignment, and with Jerry's help we had the problem corrected in about 30 seconds.
Frank & La Donna Bodden
2004 Sea Breeze LX
Once a Texan, always a Texan
sum1
So-Cal
Posted: 10/11/09 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
If it's always been like that, it may have been installed improperly. But, sometimes, if your awning strap is rolled up to one side or the other and not spiraled on near the center, it can cause a misalignment. I start mine just one side of center and spiral it on towards, then past center to avoid a lump. Imagine the extreme case of starting the strap at one end and allowing it to wind up directly over itself. That side would certainly wind up tighter and could possibly cause a misalignment.
