basmit1
Ontario Canada
I have a 2007 Springdale 38 Foot TT with two slides. The TT is on a permanent site and has not been moved since it was new. I am hooked up to shore power all the time. I went to move the bedroom slide in and it would jerk ahead but would not move in. I got the wife to push the button on the switch while I pushed on the slide from outside. We got it to move a couple of inches at a time untill it closed. Now that it is closed it will not open. The slide is tight all the way around except the right bottom corner. I am going to put something in the corner to seal it for the winter and worry about it in the spring.I looked under the trailer and saw no obstuctions, but never thought to check if the motor was engaging properly.Any help would be appreciated as I am a rookie at travel trailers. I use the TT the odd weekend in the winter. Is it okay to sleep in the bedroom slide when it is retracted. Thanks.
Jacksons
columbus,ohio
my first guess is that your battery is bad,or has a bad connection to ground. clean the battery terminals and connectors
2002 Rockwood 8272s
2005 Yukon xl Denali 6.0
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
basmit1
Ontario Canada
Don't have a battery. I use shore power all the time.
doxiluvr
Tucson-AZ
We have a 2006 Sprinter and the slideouts will only work on 12Volt battery power even if you are plugged into shore power.
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 longhaired mini-dachshund, Hannah
4 grown kids, 6 grandkids
1 2007 Yamaha v-Star 1300
basmit1
Ontario Canada
I used slide outs last winter in the cold on shore power with no problem.
curveballer98
Hancock, MI
rusty, in need of lube, fluid in the resevoir for the hydraulics?? my owners guide for my springdale recommends when parked for any lenght of time to bring the slides in and out i think it said once a week. to keep things lubricated and moving smoothly. do you have slide supports? i know they aren't recommended and if you have them, they may have settled causing your slide to bind up.
skipnchar
Topeka Kansas USA
My guess would be your battery has been fried by sitting with the charger on for that long. No battery power, no slide movement. Put some jumpers on it or replace the battery and you'll PROBABLY have slides again.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
robsouth
Near Atlanta, GA
Good Sam RV Club
basmit1 wrote: Don't have a battery. I use shore power all the time.
Never seen a slide (or other appliances for that matter) that perform as they should without a battery. Are you sure you don't have one? Shore power will keep your battery charged somewhat, but it can also "fry" one if the battery is not checked for water periodically.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
basmit1
Ontario Canada
My trailer has never had a battery and everything works fine.I do not use supports and the slides are not hydraulic. There is plenty of power going to the slide motor. It feels like it might be binding because the slide pulls to one side then jams.The gear tracks,rollers and slides under the trailer are rusty so lubrication may be the answer. What do you lub with. Is it okay to use the slide bed when it is retracted. Thanks
robbie69
wauconda, il usa
here's something i found that has helped me immensly. thought my slides were all screwed up and a few shots of this did wonders. i didn't lube the tubes but i did give the rear rollers a shot also.
read here
they say it's for squeeks-but mine were far beyond that stage and have been working quickly and quietly-just like new since i 1st did this.
also may want to drop a batt in there. don't know how true it is or not, but was once told the reason they need a batt is they are alot like car started motors in that they are hi amp draw motors and need the hi cranking amps not supplied by your converter/charger.
edited 10/14/09 02:45pm by robbie69 *
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
