RV.Net Open Roads Forum: Tow Vehicles: Hmm, Pee will save the planet?
Search only in Tow Vehicles
 > Hmm, Pee will save the planet?
Tow Vehicles Related Tips
Pauljdav
Everett, Wa
Posted: 10/16/09 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
SoCalDesertRider wrote:
Pauljdav wrote:
flamer4dodge wrote:
My Cummins does not need this inferior technology. Once again the mighty Cummins shows it's dominance.
Is this because Cummins has "EPA credits" they can use so they were able to push out until 2012 to be compliant?
No, it's because their engine meets the tailpipe emmission standard without the extra equipment. Simply put, their engine burns cleaner.
Hmmm, Maybe you should read this,
Recently Cummins announced that their 2010 Heavy Duty engines would NOT use SCR to meet NOx emissions. Cummins stated that 2010 heavy-duty engines will use no NOx aftertreatment, relying on technologies such as 'the XPI High Pressure Common Rail (HPCR) fuel system, next-generation cooled Exhaust Gas Recirculation (EGR), advanced electronic controls, proven air handling and the Cummins Particulate Filter'. Missing from this announcement was the significant fact that Cummins must use banked NOx credits from current production engines to offset NOx emissions from the 2010 engines that will in fact exceed 0.2 g/bhp-hr.
Snowho2
Sparks
Posted: 10/16/09 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Just another reason to buy the mighty Cummins.
RollingRockTX
Keller, Texas
Posted: 10/17/09 12:28am Link  |  Quote  |  Print  |  Notify Moderator
guess you didn't read it.
Rob_NC
Walnut Cove, NC
Posted: 10/17/09 10:40am Link  |  Quote  |  Print  |  Notify Moderator
This news is over a year and half old. There's newer news here...
http://www.dieselnet.com/news/2008/08cummins.php
Rob_NC
Walnut Cove, NC
Posted: 10/18/09 08:18am Link  |  Quote  |  Print  |  Notify Moderator
After completely missing the point of this post before, I will point out the last sentence in the paragraph above shows why the 2007 and above Dodge CTD is 2010 compliant. No other reason to produce an emissions level before it's due than to gather credits for other products. The engine refered to above is the 15l ISX.
RollingRockTX
Keller, Texas
Posted: 10/18/09 08:50am Link  |  Quote  |  Print  |  Notify Moderator
"The new 2010 Dodge Ram 2500 and 3500 Heavy Duty pickups don't use DEF to scrub NOx because they carry over the existing NOx "adsorber" catalyst that's paired with the 6.7-liter Cummins I6. However, 2010 Dodge Ram 3500, 4500 and 5500 Cab Chassis trucks will use DEF.
DEF will also be available in multiple bottle and canister sizes, so it cab be stored in the vehicle or in a garage. It has a one to two year shelf life, depending on temperature."
houtrz
Lake Jackson Texas
Good Sam RV Club
Posted: 10/18/09 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
From the article, "They are more efficient than petrol engines, which means they emit less carbon dioxide, but they also pollute more".
I do agree with this to some extent but if a diesel engine is using less fuel, that means that less crude is pumped from the ground, shipped to a refinery, processed into fuel, shipped to a terminal and finally shipped to a gas station. If you add up all the savings from not having to ship the saved fuel to begin with, would you not come out better?
Rob_NC
Walnut Cove, NC
Posted: 10/18/09 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I've been buying it in 2.5 gallon jugs, 55 gal. barrels, and 275 gal. totes. It does come in 1 gal. sizes also. It will always be cheaper in bulk by nearly 1/6. The TA's I've called are selling 2.5 gal. containers for nearly $15 while their at-pump prices are $2.65/gal.
