DDinCincy wrote: If you don't, things WILL freeze! Parked, my wet bays will maintain 50's to 60's even with outside in temps below 20, but when driving, those bays will drop into the low 40's or 30's even with the furnace running.
Your furnace is sealed. Their is no way wind can get to it.
My rv is not set up for winter use, I do not have heat in the wet compartment, Has anybody ever modify theirs to have heat down there. The last time I was cougth in very cold weather I placed an 1500 watts electric heather in the compartment where all the manual valves are, hopping it would do some good, after a while I got concern about the safety of doing this so I turned it off. did ok. I was parked at the time.
